Buy computer at Sim Lim
kjke1986
Would like to purchase a computer from Sim Lim, are there any reputable shops/retailers?
I used to purchase from Bell but they have closed already.
Thanks.
ykgoh
Not the cheapest but good: PC Theme.
Cheap but a bit risky: TradePac.
waiken
Well, I think if u need to ask then I think its a no no for you.
Just search for TradePAc in the forum u will get the general idea
never buy from them before but i do know some stories but thanks anyway :D
Hailgod
Thanks.
are u buying computer or computer parts?
Jian19
Get from pctheme if u not sure about pc stuff
Maybe stat ur budget and usage and we can help u list out a decent build as reference
Maeda_Toshiie
Thanks.
Important questions prior to further discussion:
1. Usage pattern
2. Budget
MoneyFace =p
I am buying a computer. not parts.
Consult Dell Direct
Shops will only support you within first 7-30 days (depending on shop policies). Rest is still up to individual hardware parts' distributors warranties.
royfrosty
Its a strange thing that you have said Bell. If your previous PC is a DIY PC, so are you getting a shop to fix a DIY PC for you? Or you want an OEM Brands like DELL, HP, Lenovo etc?
seaknight
Diy pc, pc theme is one of the best, next would be fuwell.
However, both are at the slightly more expensive end, you must know how to bargain lah.
Tradepac is cheapest but you must be careful.
If u r after oem pc, then check dell, Asus, etc.
Bros here would have given u enough advice le. :)
