Building a Gaming Rig. Advise needed
DragonQuan
I would like something that is super reliable, and hopefully, long lifespan.
Processor: i5 4670
Mobo: B85 or H87 [Need advise on Brand and whether to use B85 or H87. What are the differences?]
GPU: AMD R9 280X (Cannot decided on brand due to different theories from different people. Some say ASUS due to the "better quality", Some say other cheaper brand better because "cheaper and doesn't make a different which brand. All the same"
HDD: 1TB [Should be going for a WD one due to good comments by most ppl i talk to]
PSU: Something that will not burn, preferably modular. Enough to run the set up and better to be able to run the set up if I add an additional GPU [Have heard horror stories on burning PSUs.]
Casing: Considering CM 311 (Looks does not matter. As long as its good for cooling to prolong parts lifespan, would be good)
Ram: 8GB or 16GB [Need advise for brand and either 8 or 16]
DVD drive: I will need one. Seems they are dirt cheap so its not that bad.
Cooling: Stock or not?
Moniter: 23 inch [Brand recommendation please]
Also, would like to know the price. I have a general idea of what it would be, but good to double confirm
THANKS!
royfrosty
Processor: i5 4670
THANKS!
You can say what you need and what you really want. But no budget allocated?
Paying more does not mean will last long. And paying more for premium does not mean it will last long also.
Its heng or suay thing. Some even buy Asus top tier mobo and fails within a few months. Some buy Biostar and lasted a few years.
What else do you need? Whats your budget?
Do you need keyboard mouse? Do you need wifi? Do you need Speakers? Do you also need an OS win7 or 8.1?
DragonQuan
Keyboard mouse - no need
Wifi - Using lan.
Speakers - Yes
OS- No need
Budget is ~1.5k. Hard cap of at most 1.7k
royfrosty
Wifi - Using lan.
Speakers - Yes
OS- No need
Going for blueish theme and with synergy build
MSI B85M G43 + i5-4570 ~ $347
Kingston HyperX 1600mhz 2x4gb kit Blue ~ $115
WD Blue 1tb ~ $76
Samsung EVO 250gb ~ $179 (Amazon)
MSI R9 280X 3gb Twin Frozr with BF4 bundled ~ $469
Seasonic G650 650w 80+ Gold Modular PSU ~ $135
Fractal Design Arc MIDI ~ $129
Samsung ODD ~ $21
Swans m10 2.1 speakers ~ $109 (Cybermind or PCthemes)
Total ~ $1580. Buy at tradepac. DIY
MoneyFace =p
Full Red-black ASUS ROG-like theme build! :s12:
CPU+MB: Intel Core i5-4440 + ASRock Fatal1ty B85 Killer @ $345
RAM: G.Skill RipJaws-X DDR3-1600 CL9 8GB Dual Channel Kit [Red] @ $113
GPU: MSI R9-280X 3GB GAMING OC [BattleField 4] @ $467
SSD: Kingston SSDNow V300 240GB @ $199
HDD: Western Digital Blue 1TB @ $76
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
PSU: Super Flower Golden Green HX-500 [80 Plus Gold] @ $88
CASE: Sharkoon T28 [Red] @ $78
DSP: Dell S2240L 21.5" LED [e-IPS] @ $199
SPK: HiVi Swans M10 [2.1] Black @ $109
Total: $1695
Optional:
PSU: FSP Aurum S 500W [80 Plus Gold] @ $105
If Super Flower PSU still OOS.
Buy and Build from Tradepac, #05-18.
DragonQuan
Total: $1695
Optional:
Due to personal preference, i5-4670 is needed so thats like $36 more but SSD is not required so minus $199 as it just increase boot speed which i dun really mind, unless there are other factors which i have missed out.
However ,would changing out the MSI GPU for a Powercolor one have significant differences? such as reliability and performance?
StopJoking
SSD will improve boot speed, shut down speed, installation speed, apps startup speed, even the browser start up speed. reliability and performance also much better than normal HDDs. its definitely a good investment
royfrosty
What are you needing on the just extra 0.2ghz from the 4570 to 4670?
You buy an entire rig at this price and you not gonna add in the SSD is a waste.
SSD bring in certain benefits. Not only boot time for PC. It is also reliable than a HDD alone. No mechanical parts and no moving parts. Your OS overall stability and also responsiveness is there. Say goodbye to slow responsiveness to certain things stored in HDD. Not unless software bugs or hangs for whatsoever reasons.
Games on SSD also gives a upper hand on certain MMORPGs. Giving good load time also gives you upper hand to maneuver your next moves. Not only that map loading is faster. Im sure games like D3 benefit from SSD loading also. Is about life and death when you see blank screen and mobs are attacking you instead and you can't do shyt.
Games like FPS battlefield 4 also benefits from fast loading. Grab a tank, helicopter and also buggy ride and you are good to go. While HDD loaders are still loading and probably have to walk on foot.
MoneyFace =p
:s13::s13::s13:
DragonQuan
My main game now is World of Tanks now which runs on 1 single core so I have no choice but to go for something with a single faster core speed. Also, I am planning to stream. Would like to ask whether for streaming whether a more powerful CPU or GPU is required for better performance?
Hailgod
streaming requires a decent cpu and a good internet. gpu is not a factor. The 0.2ghz wouldn't magically let u stream if the 4570 can't. Not saying it can't though. Its easily powerful enough.
To add on, Most game aren't even cpu bottlenecked. Its the gpu. Spending that extra $30 isn't going to help at all. You would be better off with a nice meal before your game
DragonQuan
What I'm afraid is World of Tanks might really bottle necked by CPU because it runs on 1 single core.
DragonQuan
Apparently world of tanks run way better on nvidia graphics card than radeon ones. Free-to-Play Games Benchmarked: 4 Popular Titles Put to the Test > World of Tanks Benchmarks - TechSpot[/url]
Might want to change the 280x to a 770 instead
actually quite shocked by nvidia trashing radeon. Nvidia use too, or still has issues with World of Tanks. Makes it crash frequently
royfrosty
Both camps till date have driver issues. Go with anyyhing you feel comfortable with.
