DragonQuan
- Feb 1, 2014
I would like something that is super reliable, and hopefully, long lifespan.
Processor: i5 4670
Mobo: B85 or H87 [Need advise on Brand and whether to use B85 or H87. What are the differences?]
GPU: AMD R9 280X (Cannot decided on brand due to different theories from different people. Some say ASUS due to the "better quality", Some say other cheaper brand better because "cheaper and doesn't make a different which brand. All the same"
HDD: 1TB [Should be going for a WD one due to good comments by most ppl i talk to]
PSU: Something that will not burn, preferably modular. Enough to run the set up and better to be able to run the set up if I add an additional GPU [Have heard horror stories on burning PSUs.]
Casing: Considering CM 311 (Looks does not matter. As long as its good for cooling to prolong parts lifespan, would be good)
Ram: 8GB or 16GB [Need advise for brand and either 8 or 16]
DVD drive: I will need one. Seems they are dirt cheap so its not that bad.
Cooling: Stock or not?
Moniter: 23 inch [Brand recommendation please]
Also, would like to know the price. I have a general idea of what it would be, but good to double confirm
THANKS!
Processor: i5 4670
THANKS!
