royfrosty
- Jul 23, 2009
actually the gtx 460 can still be reuse ma since he light gamer and mostly browse web nia
For his gf not himself... GTX 460 too potent to play FB games...
G.Skill Standard 1600MHz 8GB ~ $87
MSI B85M-G43 + i3 4130 ~ $287
Fractal Design DEFINE Mini ~ $122
from MNC pricing but perhaps bro here got other recommendation can be cheaper
Possible upgrade option:
MB: Gigabyte GA-G41M-ES2L^ @ $45 (CDL Trading Service Centre)
SSD: Kingston SSDNow V300 120GB @ $115
CASE+PSU: In Win BK644 [White] + Powerman IP-P300BN7-2 300W SFX [80 Plus] @ $103
Total: $263
Optional:
CPU+MB: Intel Pentium G3220 + ASRock H81M-HDS @ $148 (Tradepac)
RAM: G.Skill NT DDR3-1333 CL9 4GB [Black PCB] @ $45 (Tradepac)
Buy others from myneXtcom, #05-26A.
Ah thanks for sharing bro.. Yeah in future, my old ssd will be going there.. So b85 then
Actually I prefer Asus more.. Can recommend their b85 matx mobo?
How is the g3220 compared to i3 4130?
ah then nvm.. lol msi ba.. their capacitors also good one right? I want long lasting one..Erm their price more premium and for same features wor, you prepared to pay?
H81 will do, with 2 ports being SATA 6 Gbps and 2 USB 3.0 ports. Anything more will be superfluous.Ah thanks for sharing bro.. Yeah in future, my old ssd will be going there.. So b85 then
The igpu on 4130 slightly better, got hyper threading and clocked higher abit lo. In gaming not that much diff ba..
Igpu is more for on board? So if I got 460gtx it doesn't really matter right?
bro thanks a lot for the help!yepp doesnt matters, its up to you, but if i were you i would pay the premium to go i3 cause of the hyper threading. If i never remember wrongly games like BF4 can acutally make use of the hyperthreading to perform better, and maybe new titles might follow suit. If you are sticking to D3 its fine but if you want to play new titles i think i3 is more suited, though I5 will be the most recommend for gaming.
anyways, how about AMD + mobo? Are they still offering any best bang for buck combo?
ah thanks..one last questionI would say do reconsider Intel cause you can try compare their prices, they are quite similar in Singapore but only in other countries you might save abit more.
the stock hsf for g3220 or i3 4130, are they good enough? need after market ones?
