Air purifier?
Panerex
Anyone plan to start sourcing for air purifier again?
Preferred those true hepa filter type
sky00sky
thinking.....have a Honeywell 17000 already in my kid room.
If Haze bad will bunk inside..but
Since it is like going to be a yearly thingy wanna just get one put in MBR
Sharp 401 or BLuAir 203,403 in the cards.
AS1
depends how much you want to spend. Either one big one or one in each room.
My plan is to get one of those $2xx ones and put inside each room. That way if one spoil, still got the rest.
Looking at this Novita model now.
AS1
This one good ?
One unit supposedly is okay for a hdb single enclosed room.
Too bad singapore dont have standard sticker for recommended units to use during haze.
chech01
This model is 199 now.
BrOwnTeddy
I am looking at this:
But I am wondering if it really lives up to what it claims... 40m^2 and can suck in PM2.5 pollutants. :s22:
I am looking at this as well:
The FU-Z31E. The coverage for its plasmacluster is about 25m^2. I like the plasmacluster technology (it really works, damnit) but the coverage is a little small.
Of cos, can always buy from Amazon since its cheaper than SG.
Honeywell 17000.
But how is it really? Noise and coverage wise?
ichise
Using that Novita model for about a year now , so far so good ( using in a small air-conditioned room for my kid )
There's 3 power lvl , the Hi mode is noisy tho .
hope it helps :)
BrOwnTeddy
hope it helps :)
Shucks. Noise. :mad: I am expecting that small unit to generate lotsa noise since its pretty concentrated.
WussRedXLi
Courts OOS liao.
Harvey left with some Hitachi @ 399. Philips @ 899 (who will buy at that price and features/performance).
Never go BEST to look see.
Just some info...
ichise
Yea was shock when I first on it on Hi mode , medium-mode noise is still acceptable , seldom on low-mode ( I personally think its weak )
AS1
Depends on the setting.
My plan is one unit per room so $199x4 is less then $800 so still reasonable. Right now the psi is still okay okay so will leave at low first. Worst psi case scenario is put all the units at full power into main hall and whole family sleep there.
blues7
So far all models and brands I've tried have some noise
OSIM, Novita, sharp, Panasonic or Philips
Yet to try Honeywell becoz always sold out
Panerex
Which sharp model is using true hepa?
I don need any humidifier or ion function
