hi all i have a problem here. Previously i rooted my hongmi ver12 with framaroot and downloaded link2sd app, still couldnt move my apps to sdcard so i just keep it in box again. then somehow i on the phone just now and started playing ard with the functions and saw an update software ver13 so i proceeded to install latest version, now i cant on the supersu app.
it have a error message "there is no su binary installed, and super su cannot install it. this is a problem!"
what does this mean? my phone is rooted or not?
I got one from the March order but LED indicator is not working, it doesn't lit up not matter what, be it receiving e-mail, incoming calls, whatsapp etc.
Not sure if I've got a lemon or software configuration issue, i checked "Pulse notification light" under 'Setting", it is turned on.
thanks for replying~! anyway to remove the supersu app??? see liao not happy~!You have to choose move to sd within the program
Rooted, ver13 not compatible with framaroot. Wait for update.
thanks for replying~! anyway to remove the supersu app??? see liao not happy~!![]()
hold your horse for those buying at marketplace. don't kenna chop carrot!
Buy from telcos likely to carrot chop too. Best is to camp yourself haha
Examine the plans before re-contracting as it's a budget phone the 'subsidy' is low. Alternative is to re contract for another phone with higher subsidy. Sell it off and use proceeds to get the redmi.
So long as getting from xiaomi.SG or telco no worries. Getting from other sources not only risk getting non compatible version but risk of getting fakes.
anyone got error receiving sms from ibanks? the messaging app keep crashing
Basically is a zero value phone for those low end plan. Anyway, I guess there is other better choice in this range.
I think most subsidies runs between $200 to $400 depending on the plans. The Redmi retails just for $169 and although is a good phone, is not one I find worthwhile to be on a contract for. There are more premium phones for contracting.
The redmi is a good phone if you are not on a contract.
Recently Singtel came out with 'SuperLite' phone with small amount of data (100MB). With that plan, RedMi price is $68. I think they have additional plan discount for senior citizens. So at least seniors can use whatsapp/line/wechat/etc on-the-go on their RedMi?![]()
how do i delete the themes which i have previously downloaded but no longer using?
