Note 3 Price Check
otacon
RWM sell for 778. bought it ytd, they said is agent set.
i just went there, when i asked if it is telco set or not, they said dun know. they said nowadays they just take whichever is cheaper. they will not know until open up.
pixelspics
Recently bought my note 3 also from red white mobile. Mine probably is a telco set set cause i saw 3 M1 application. Anyone noticed it?
IcYFl4mEz
they told me mine is agent set, cos i ask so when is the warrenty start? he say since today buy today start,cos telco de is when that guy sign line that day start ma
seller4
The Samsung suit of app itself is worse bloatware than that of the Telco's.
True but that one telco or retail all have. If really cannot tahan them, root n freeze/remove them bah.
On the other hands, if you hate Samsung bloatware so much, maybe you buy some other phone. :)
---A Samsung Connections member.
seller4
But as long as the seal is intact n no bloatware, it is ok rite?
so u r kind of promoter for samsung?
Yes.
Not really a Samsung promoter. I dun swear allegiance to any brand.
Before invited to join the Samsung Connections group, many of the members are already here to help/give suggestions to forumers on Samsung phone questions.
Samsung saw it and invite us to join the group.
seller4
So did you see any my m1 icon when you bought your note 3?
Nope. No telco apps when I bought my Note 3.
The "Singtel Menu" icon only appears when I insert my ST SIM Card into my Note 3.
Swayer
Does this means in future, power up a new phone without sim card to check if it's a agent or telco set?
seller4
For me, yes, I will request shop to let me power up without SIM and check and ensure it does not have telco installed apps.
wayneee
im planning to get the phone...see that both htimobile and red white mobile selling $778...any idea if one is better than the other? or i can safely get from either place? :D
pixelspics
I am not sure which one is better but for Htimobile seems that when you top up 15 and you get the samsung original power bank worth $58 according to their facebook. Just for your info.
