Has anyone got the same misalignment of the front glass panel? If you see the top right, there is actually a gap which is not apparent present on the left side.
the docking station got another piece of plastic is use for wat? currently using my psv charger to charge my z2![]()
My z2 which is a white one has this problem too. My front camera is not seated in the middle of the hole(more like towards the top right)
Anyway has anyone rooted z2? Our version can root without unlocking boot loader? Don't wanna void the warranty
StarHub said all their branches no stock
Checked causeway point personally and they were out of stock
How you all see sia. Front camera got what hole?
The camera should be in the middle of the hole
Same problem.. Should go back sony do a exchange?
can post photo see? My dad gotten a UK 2 pin plug in his z2 box.. same as the 1 in z1..
how you see?
Yours look ok.. your top right don't really have a gap, your camera looks fine.
