The Xiaomi Mi3 thread
TUV2008
Anyone knows how to delete a city under weather app? I can add but cannot find way to delete it.
pv2008
Press menu > locations > select city > delete
This may depend on the theme you are using but there should a circle/square with a tick in front of the city name. Once you tap that symbol, the option to delete will show up at the bottom.
win_man
Anyone know if the Dev Rom 4.4.4 for Mi3 support SG WCDMA?
fyeebiyd
Does this phone have the function of automatically turning on wifi when recognized SSID is detected?
In addition, did anyone installed any app that can remotely control the phone so that it can be wiped or tracked if you lose it?
BlitzStryker
Go Google ixiaomi for the tracking thing.
It's Xiaomi cloud storage website for all your stuffs.
doki81
yes...it has the feature to turn on when known ssid is nearby...
the tracking also have which is the micloud...once sign in to micloud..u can sync contacts...sms....picture....and also track phone and wipe..
fyeebiyd
Thanks both. Will explore the phone more and learn how this works.
s7460597
Anyone knows how much does it cost to replace the battery at the Customer service centre? Not changing know just wanted to know.
BlitzStryker
The earpiece jitao oos?! Usually I still can buy the phone easily but the earpiece was straight oos? Haha
Edited: end up got stocks and end up bought than 4. However the status at Xiaomi didn't update like previously 27th March redmi sale incident.
