Exchange Rate
calkel20
You cant predict the rates would go up or down.
You can only use the past rates trend to determine, if last few days rates are going up, then you change today, the rates might be on the up trend.
Marina Fountain and arcade provides good rates.
However, think arcade rates are higher, maybe more stores there then more competitions :) One store change THB higher, doesnt mean their HKD might be high. But difference wont be big, maybe 6.16 and 6.15 for HKD.
So must check different currency rates if you want to change different currencies.
True la. If iwant a different currencies, i will shop around.
dede1217
But sometimes if the queue is super long, like 10+ ppl infront the store, would rather forfeit the 1HKD difference and queue up other store lol...
SibehEng
change at fountain money changer (move to marina sq) today.. 23.6.. however they got no small change, smallest is 1000NT note.. change some and maybe gg over tw then go dbs tw change.. is 1000NT difficult to break into small change from tw stall?
calkel20
Very easy to break and commonly used. No worries.
calkel20
alright thanks.. gd to know.. dun wan to be given a boo hand sign by the stall owner for making them having find small notes.
No worries, can always break your notes in convenient stores. There is always one literally at every corner of each street.:D
tian1031cai
The money changers at Tao Yuan Airport gives really good rates
There are many money changers at the airport and they offers the same rates.
Would recommend you guys to change TWD there
calkel20
No matter how good, it has lose it's advantage to changing at arcade and each transaction you lose about 30NT, may not be a lot but still. Unless you cannot find time to drop by Arcade, Raffles place, then there it will be your best option.
calkel20
If one has to drive, or take public transport to arcade, might cost more than NT30.
Solely depends on how much are you or they are changing. Normally, it will be at least 500SGD and above. If you say 1-200SGD, then can forget it. Change airport also can.
Some theory for USD and other currencies.:)
dede1217
Think normally travel to taiwan, my friend and I we usually change around 300+ to 500 each person lol ... Normally would change at arcade because nearer to my house there ...
BigMonkey
Is it specific to a particular night market ?
Go Taiwan tourism board in SG to get ?
the night market that are valid are indicated on the pamphlet.
look put for the logo indicated in the pamphlet, not all stall can use the voucher
calkel20
not really, i see the voucher as a push factor to go to places when one is clueless about where to go.
fwah~ shu shu waifu ish taiwan lang?
No point go there in the end all bo ho jiak.
Why chiu want to stalk me ah? Or u want to jio me go jiak buffet? I beri on de.
