kimurastanley
- Sep 21, 2009
should not be any problem. May be you need a plug convertor for the pin
Dun waste time cos the 64gb not much usable space. Unless you are thinking of storing most of ur stuff on the sd card, thumb drive or cloud, the 64gb is outright claustrophic with much of the space taken up by the os. @@ 128 gb is slightly better. 256 is perfect.Any recommendation on the models? 32gb/64gb/128gb
Thought the 64gb one might be an optimal mix of storage size and cost.
You will be sian-ed when you realised you can't access certain website encoded with Javascript. But I was assured by Surface Team in Microsoft that their team is working hard to get Javascript working just like our phone's Java applet. But then again, he said it still depends how fast Oracle revert back to them with the coding to Microsoft team.
For those on Surface RT/2, if there's certain websites that dun seem to work, try running the same site your desktop's IE instead. Toggle the compatibility settings if needed.
I know it worked for me on some sites.
Some buttons are still not working in Surface 2 desktop IE. Especially website that runs complicated javascript with intranet. (i.e school web-portal)
Tried, adding and removing them from compatibility sites.. no use
Agree! My school blackboard buttons not loading =.=.. not do document then pump in to thumbdrive go school computer and submit..
We just bought something unproductive!
Thread carefully cos once buy liao, impossible to upgrade unless you open up to upgrade the ssd.
128 gb also easier if u r using the sp to semi replace ur desktop. Booked my 256 from vshop. Abt 1.8k. The shipping was the jialat part. Else, its ok.thanks for the advice. maybe i'll look at the 128gb. the 256gb is really wayy too ex heh.
Also,for gaming 8Gb 256Gb is better. 128Gb has only 4Gb and video is sharing the memory.
Yeah..but currently gaming on my sp1. No issue also for Diablo, StarCraft, Pro Evolution Soccer 4 and Metal Gear Vengeance.
Seems to be running OK but I suppose performance sometimes stutter due to lack of memory.
