Wireless IP Camera thread
nahbehism
Is there a ip cam that comes with email alert on motion detection?
I used to own a prolink ip cam.. the email alerts just suddenly stopped working
user109s
Most of them does.. Try to reset to factory default and try again. Hopefully it just a minor bug error so factory reset will clear it away. If not, RMA may requires.. :)
doran_lum
How do you power off vstarcam ip camera ?
On the app i notice there's only a reboot option. If just switching off at the power source is the way, would it corrupt the memory card ?
Lit3s
Hi guys,
need some help here. I'm on Starhub Fibre using the Dlink gateway. After re-setting up my foscam, i can view it using the program on my computer running on lan.
Iphone etc running ip camera app also no issue on 3G/4G networks. However when connected to the same network on wifi, it just wont load or connect.
i've check the ports are open. Any idea where went wrong? :s11:
user109s
Hi guys,
You can try to reboot the gateway. Sometime may require to reboot both the router/gateway and cams.
geckoSG
No power button. Just off directly. Yes, will corrupt clip in long term.
geckoSG
No logic or requirement to power off the cam. Most of the cams in the market couldn't be sw off by remote. It's useless if it's not on for all time surveillance. :s8:
You will b surprise on the number of people who will turn off the cameras daily to save electricity
Linus
I bought a Dlink 5222L (camera supported by Surveillance Station for Synology NAS). Tried to add it in Surveillance Station and was able to get a test connection working. When I choose the video format as MJPEG, it is working fine. However, when I select MPEG4 or H.264 as the video format, the test connection works but Surveillance Station shows camera is disconnected and display error message that the connection is lost.
Any ideas?
user109s
Oh well, by doing so yes, it'll save some but it'll cost you more; itself break down.. Chance is high. Just like some people will switch on their TV but not in stdby. The break down chance is often high. My TVs are all on stdby not switch off cos little current is consumed.
The trade off of this little saving goes none when other electric devices are on; electric kettle, aircon, heater, computer. Even thought you charge your all IOS & Android devices overnite.
You will amazing how much you'll spend electric $$ on the charging devices over a month.. :s13: Do you use timer to control your chargers? Ya.. I thought so.. :)
rickyc
Which ip camera to buy ?
Hi all,
I'm looking for an easy to to setup, good quality ip camera (in terms of features, picture and support) to use at home......which i can view from my pc (win8) or android phone. Budget ard $200-$300. Any recommendations ?
Thanks in advance,
Ricky Chin
geckoSG
just saw that MARIX got a mayday midnight sales promotion for VStarcam IP Cameras, so far no see anything on their eshop. Maybe really must wait til midnight before models and prices can be seen.
HeeroYuy84
I am looking for cheap Poe camera compatible with synology bad,any recommendations?
geckoSG
DR_Archer,
The T7833WIPX3 comes bundled with 32GB MicroSD Card, pricing is same as the same MO price I arranged the other time. You might want to consider buying from them online instead.
geckoSG
user109s, when you get your wanscam, can you tell me if it can do a -20 to -30 degree downward tilt when placed upright?
Thanks!
