Transformers Toys
tErOn
Hi All,
i made some el cheapo display floating shelves from the following materials
Ikea EKBY LAIVA Shelves $4 each
Ikea EKBY STÖDIS Brackets $1 each
each shelf will consist of 2 brackets and one shelf board so thats $6 bucks each..
will show some pics when i get home tonight..
after mounting the shelves i measure the distances and go to a local acrylic store to order custom acrylic sheets (2mm thick will do) and use foam tape to make a channel for the acrylic pieces to slide in and out..
acrylic sheets cost like $4 to $8 a piece depending on the size..
from dama.com.sg
you give them the measurements and thickness and color, they will quote you
Heres the pics of my el Cheapo display rack..forgive me for the dusty corners..was in a hurry to go off to work this morning..
Acrylic sheets were used to keep out the dust
Closer view of the cornet
Foam tape was stuck on at intervals to keep the acrylic sheets in place..
sKeLeToN
i got it from big bad boys store :)
Thanks mate...
You think any store at CSC taking orders for this? I did see a local ebay seller quoting price of S$110 for each limb and $150 for the main body...as preorder. Still prefer to get locally...you know of any store that brings in this?
Anyway, looks like Heavy Noisy is gonna release soon!
Exciting times ahead! :s12:
warboy85
Thanks mate...
u can try roboconcept. from facebook
tErOn
Thanks mate...
wah lau eh!!!!! *DROOL* at the tank!!
seriously im considering hooting the entire warbotron just for this tank :s22:
xiaoheng
any bro here know where can i find Tomy DOTM Leader class Optimus prime (jetwing or striker) in singapore and how much would it cost now? tia
albatross078
ebay, csc or any toy specialty shops . jetwing is cheaper than striker, as striker is exclusive to asia.
around $2XX to $3XX
tErOn
I just completed and completely poisoned myself - ordered both Warbotron and TFC Prometheus :s22::s22::s22:
wah..hw much u order warbotron?
around $2XX to $3XX
i saw the KO version at KSL City..so cheap it hurts cos i nv buy KO version before..lol
