LG G3
BuShuang
No leak on dimensions? I dun want a huge phone sticking out of my jeans...
Hisashiburi
It isnt unibody.
The leaked pics show a crease in the body, like on the Samsung s4.
The base also has a little indent to open the back case.
So u can be sure there will be a removable battery and prob sd card.
The dimensions dont look too big either.
Seems smaller than G2 Pro.
If it's really a unibody, how will we be able to insert our micro-SD card if there's really a slot for one?
The SIM card, on the other hand, can be like the iPhone-type tray perhaps.
Nuclear Boy
It isnt unibody.
If that's the case, definitely will be on top of the list of my possible choices!
But isn't that indent the micro-USB socket? Otherwise where else would it be for LG phones?
Hisashiburi
Could be mini-usb socket but in any case, there is the crease to open the back panel.
U can see that the back panel can be separated from the top part.
kelvinti
That, could be the Korean model for Korean domestic market only.
The international model does not. :(
LG makes the G3 different from Pro 2 to cater for different segment of consumers.
A marketing strategy! Those international consumers who wanted a removable battery and SD card would have gone for Pro 2 or Pro 3 next year.
As for G3, it does has a big market internationally for consumers who do not really concern or need removable battery and SD card slot.
Hisashiburi
Arent u being a bit too pessimistic? :)
If the G2 had a removeable battery, the G3 will.
kelvinti
We certainly hope so that G3 has both! :s22:
Then, G3 will be selling likes hot cake especially in this part of Asia! :)
Hisashiburi
From this pic, seems like the bottom bezel is huge!
Plus adding in onscreen buttons means a lot less screen space.
Hope not though...
edit: Bezel size looks similar to the G2...
kelvinti
Yeah! A 5.5" on spec. means a 5.3" actual screen for apps as the other 0.2" will be taken up by the on screen button aka. OSB. ;)
As for the bezel at the bottom, I guess it has the same dimension ratio as the Pro 2. It looks just a bit bigger on a smaller G3 bah...
Nuclear Boy
Not sure if anyone still tunes in to FM radio nowadays lol, but I can hazard a guess that the G3 won't have the function, just like the current ones. :(
kelvinti
I guess there will be no FM Radio aa the online steaming is reliable and popular now.
Furthermore, a FM radio drains battery as it keeps searching for radio signal on the go.
Igene
Hope not though...
Looks good.
That thing on the top, is that a TV antenna? For Korea market only (like the G Pro)?
cutebeng
hope they have FHD version,make the UI more simplified and keep it small size as possible.
gws898
I do hope there's a FM Radio. The previous 2 smartphones(Optimus G & G2) have FM Radio.
Nuclear Boy
Me too, 5-5.2 inch I can perhaps still use single-handedly. But it isn't a big problem if larger.
I thought the international models of the phones don't come with FM?
