How much PSU watts?
davchoong
My 1st pc build:
Mobo: MSI Z87-G45
CPU: i5-4670K
Memory: Corsair Vengeance 2x4gb 1600mhz
Graphics: MSI Radeon R7-260x 2gb OC
Cooler: CM Hyper 212X
1 hdd 500gb
1 ssd 120gb
PSU: Probably getting the Corsair Rm series
But how much watts?? (+future upgrades)
jtjt00
Agreed, despite many bros recommendations here, my Corsair HX620W exploded in 2 years of usage out of 5 years warranty.
shadow84
Only the corsair AX is well deserved.. they cut corners on the capacitors for RM series...
Seasonic G series or X series (If you have the budget) or superflower HX series good enough le.
hengheng220
My 1st pc build:
Mobo: MSI Z87-G45
CPU: i5-4670K
1 hdd 500gb
1 ssd 120gb
btw bro... why 260x? if gaming that is not really the most bang for buck choice...
MoneyFace =p
My 1st pc build:
Mobo: MSI Z87-G45
CPU: i5-4670K
1 hdd 500gb
1 ssd 120gb
Your build is a big no no, emphasise too much on CPU platform and everything else and too little on graphics card. What's your budget then?
Maeda_Toshiie
And that Corsair HX620W is slightly modified from the Seasonic S12II platform, and made in a Seasonic factory.
I agree that the CX and GS series are not suited for high end gaming systems running in tropical/desert climate, but HX and above stuff are mostly YMMV (ie luck).
MoneyFace =p
$1400 extrapolated from your current choice:
This one is much much better while not sacrificing on aesthetics.
DOUBLE the gaming power with R9-280X!
CPU+MB: Intel Core i5-4440 + ASRock B85 Fatal1ty Killer @ $345
Overclocking CPU is not necessary these days with speedy Intel CPUs.
RAM: G.Skill RipJaws-X DDR3-1866 CL10 8GB Dual Channel Kit [Red] @ $115
GPU: PowerColor R9-280X 3GB TurboDuo @ $435
SSD: Plextor M6S 128GB @ $119
HDD: Western Digital Blue 1TB @ $72
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
PSU: Super Flower Golden Green 600W [80 Plus Gold] @ $108
CASE: Corsair Carbide SPEC-02 @ $79
OS: Microsoft Windows 7 Home Premium 64-bit [OEM] @ $115
Total: $1409
Buy and Build from Tradepac, #05-18.
http://www.techpowerup.com/reviews/Gigabyte/R9_280X_OC/26.html
davchoong
Oooohhhhh, thx for the advice
