LG G3
Boner
At least LG phones are made in korea instead of china. The quality is there.
This is true at least for my LG G PRO 2 :)
newouverture
Look like people will stop complaining about the thickness and start complain about the battery
Yeah bro. People complain for most things for nothing even without touching or using the phone.
Now thickness of phone is dismissed, it's either battery, cpu or plastic body they will start bitching about now.
The choice is clear, not happy, don't buy. Simple as that.
Computeron
THE ANSWERS
3000mah batt... sounds weak... for a 5.5"qhd and a SD 801
kelvinti
May be LG has its secret weapon that even a 3000 mah battery is a long lasting one on G3, just likes the G2! ;)
LG doesn't stand for Life's Goondo bah...;)
MasK
Well firstly, the Korean leak may not be applicable to us. Just like G2, the Korean model may differ in terms of batt life/removable battery.
Also, 3000mAH batt may sound small now, but in real life usage, it might probably perform as good as the G2 as I've heard the 801 SOC is more power-efficient.
As for them using 801 seems kinda taxing on the GPU but we don't know how it'll perform in real world usage. It probably isn't that bad at all. Even the Oppo Find7 has similar specs and I think Both Oppo and LG are working closely on this (both using the same panel).. even the batt size is the same!
If you can't afford the G3, then get the Find7 which is $719 *I think* and a little taller. And yea.. I've tested the Find7a and it feels great in the hands and the Sony cam is pretty good.
Cheer up guys... :s12:
androidbot
was just watching the official LG teaser again and noticed within the 20 second mark, when the phone is being tossed from left to right there apparently, seems to be a crevice (slight opening) at the bottom.
There are about 4 to 5 frames in succession within the 20 second mark that highlights this so-called crevice. You will need to pause the video and move the video bar manually in minuscule movement in order to notice it.
I do not think its got anything to do with lighting but nevertheless, it could be my imagination or simply, LG tossing a metal pencil case during the teaser.. :s13:
