The Xiaomi Mi3 thread
Stuffed
Are there any retail shops selling mi3 casings? I had a look at revelion's qoo10 line ups... While they look impressive, I would like to have a physical look at them.
BERSERK1980
I had a long thought about the microsd slot too but I think the 16gb in built should be fine. Besides, my s2 lags tremendously whenever there is a microsd card inserted.
There should be only 12-14g usable. Actually enough for few hundred pics, some games and a couple movies.
caterham7
Please take note: Today's sale has been postponed to tomorrow (28/05/2014), 12pm.
As per Xiami Singapore Facebook.
Xiaomi Malaysia also same problem; seems both are using the same servers; if so, they should stagger the sale dates
Last time not so difficult to get into the system and purchase.
Saw a colleague get super frustrated last week, want to buy powerbank, managed to place in cart, then keep on getting stuck at the fill-in-address portion.
Hopefully Xiaomi can beef-up its servers.
CRViper
just got the Mi3 and sad to know the WIFI cant connect to my home network... anybody faced this issue and has a solution for this? google doesnt seem to turn up much results
maniamcool
Just received the phone today :D Awesome interface and design
Quick question though. I tried charging the phone with a non-xiaomi charger and the touchscreen went nuts. Anyone have this issue?
Works fine with original Xiaomi and Samsung Charger
CRViper
ur phone able to connect to WIFI? Or my phone got problem? :(
KYLee
i first thought it was my phone's problem. keep reseting it. turns out it was the charger.. was using fake samsung charger at that time. now using back the xiaomi charger and another 2a quality charger and problem went away
MrRayded
yeah, i get this issue too. At first i thought my touchscreen got prob but turns out it was the charger, just use official chargers can le
CRViper
only managed to get 5ghz WIFI to work, the 2.4ghz cant seem to get connected to the signal through WIFI SSID method.. only way to make it connect to 2.4ghz is to use WPS
rest of the functions seems to be ok as of today...
ecneret_eel
just bought another two casings, yday from carousell and today from revelion of qoo10.
the hardy two tone hybrid black is in stock, left 3..
or you can consider revelion rock two tone, both are similar to spigen tough armour, just that the rock casing doesn't have normal colours..
check under part a and part b
Stuffed
Hmm..I found a problem with the phone. I listen to the FM radio on earphones and when I reach office, I switched the ringer to silent mode but it also mutes my earphones!
Also when I switch it back to ringer mode, the FM radio sound actually outputs from the speaker even though my earphones are plugged in prior. I didn't realise and increased the volume thinking why is the radio so soft. The public must be thinking why am I so inconsiderate and blasting the music!
linbeier
Sumtin wrong lor... moi ringer and media sound settings also haywire one :s22:
