The Xiaomi Mi3 thread
ecneret_eel
Haha, still notch obvious enough meh? :s13:
Ok seriously, personally moi take ish other than da cheap price, other non-tangibles rike smoothness/ease of handling, appearance, built quality and overall feel all lose out to other major brands. :(:(:(
actually I'm an iphone convert..
used iphone, changed to s2, couldn't take it, changed back.
but now I'm here..
I have to note that one of the reasons that made my change easy is how similar miui is to iOS lol..
linbeier
but now I'm here..
I actually found dat kinda pretty ok too for a long time note user :)
linbeier
hmm.. meaning it isn't smooth??
cos i use gmail and I hate how the app links all the email chains together..
I get confused easily lol
does the stock app do this as well??
Email chain easier mah no nid to search separate individual mails? Moi using stock and its separate.
KYLee
other than IOS, MIUI is the best OS i've used/tried so far. compared to samsung touchwiz, i wonder how i tahan 1 year without flashing to MIUI or other rom.
ecneret_eel
no offence to Samsung fans, but i really couldnt take it, i didn't tahan also, I switched back to iphone lol
linbeier
anyway, looking forward to my new casing..
should be arriving tomorrow..
bought two casings this week, really wish spigen can produce xiaomi casings
Wat chiu using for screen protector bro? Moi using xiaomi clear sp from bundle, realli ish a super fingerprint sticker :(
cokiee
the stock calender widget can do that. Am using it with Nova Launcher, which allows you to re-size the widget.
could you teach me how I can do that please? Currently using the stock calendar widget and am contented with it's size, but the moment I tap on the date it opens up the app.
psychophant
I can see all the daily events by scrolling the widget without opening the app, unless i tap on the date to edit or add events. What do u intend to see the moment you tap on the date?
nologicboy
How much Screen on Time do you guys get out of mi3?
I was wondering if mine is low because I usually get 3.5 hours and sometimes hit a maximum of 4 hours 15 minutes. Seems a little low!
Stuffed
The batt life seems ok for me. My s2 seems to drain 2x as fast. But then this batt is new so it might be too early to tell.
The charging is also slow though.
jedi5diah
MIUI beyond what most of you guys are talking about "app preferences", there are always better apps out there.
jedi5diah
around the same as you.
this is amazing, tell me which other phones able to last this long?
