The Xiaomi Redmi thread
luei74
is there a step i missed? this is what i did:
1. select update.
2. system reboot to TEAMWIN.
3. select update. select the file from download_rom directory on my sd card.
4. verifying zip signature...
5. checksum failed.
is there anything wrong?
try to select the "restore to default" and uncheck the #checksum box"at TWNP. I got this problem too on my rooted Nexus 7 previously, always getting checksum failed during installation.
warr
did as what you said. but the error is unable to find file system /.
luei74
Can try to googling and check, my previous problem was checksum failed instead of unable to find the sys file.
adidasfreak
later is selling fake one. all hong gan.
going to SG TECH SHOW 2014?
I want to warn everyone NOT TO BUY from Booth 410, CH2. . They are selling a Redmi 1 and they are passing it off as a Redmi 1S. I bought it at $198 and the staff constantly told me and reassured me that it's a 1S.
I stood there and doublechecked again and again and it's only until I use Antutu Benchmark and CPU-Z that I confirmed that the phone is a Redmi 1. I immediately demanded my refund.
Warranty is "1 year" but it's from the retailer, so technically no warranty. BE WARNED!
TL;DR: DO NOT BUY from Booth 410, CH2.
foxbat
1. select update.
5. checksum failed.
Very odd. Didn't encounter any problem for my rooted Redmi - There is this part which asked whether u want to backup apps or data (something like that) b4 the flash process. I selected yes. When in Teamwin recovery page, selected backup box. Then after that things went smoothly.
garychengjw
Put it this way.
Only buy from xiaomi sg or telcom.
Who knows that booth might sell fake redmi.
I wonder the organiser never do proper check of their selling goods.
Pc show standard dropped.
yhw22
It is the shop at Sim Lim Square level 6, the one that selling in qoo10.
yhw22
Put it this way.
How can we stop this kind of un honesty business which is getting more. They just think we are stupid as cheap will buy.
foxbat
Bro
U mng to get a refund on the spot?
Cissiboy
would you mind being more detailed in what you did ?
I have rooted mine and I have twrp recovery
caterham7
Skyy
Very odd. Didn't encounter any problem for my rooted Redmi - There is this part which asked whether u want to backup apps or data (something like that) b4 the flash process. I selected yes. When in Teamwin recovery page, select!ed backup box. Then after that things went smoothly.
So after u upgraded yr redmi, I guess u lost root right? How did u get it back again?
I'm still sticking to ver 12 cos it worked with framaroot but duno if the new versions can still be rooted by framaroot?
deminta
anyone can advise how to do files / picture transfer from computer to phone?
i plugged in usb but my comp didnt detect anything
mosmos
High Honorary Member
or use Bluetooth to transfer, all cannot then use cloud or Google drive~
Rickosw
How to get Weekly O/S updates?
Hi XiaoMi friends!
I am getting a XiaoMi RedMi phone for my mum, at the ST tech show (under Singtel).
I once read that XiaoMi has "weekly friday O/S or software updates", how about do I sign up for it?
ie Beta Testers? or OTA / auto ?
Which telephone shop will you recommend to get XiaoMi screen protectors / protective case ?
Cheers!
yhw22
Hi XiaoMi friends!
Cheers!
No telecom at SG Tech Show at Suntec City. Get it from official telecom shops.
Weekly update is for developer only.
JadziaK
Hi XiaoMi friends!
Cheers!
I think Adix82 carries the xiaomi screen protectors and cases. You can check out his FB page
eddy2099sg
If not, you can get the redmi on June 2 on mi.com. It should not be difficult to get one.
