cases for CIEM
doki81
hi all, did you use pelican case for your ciem? if yes, which model is best fit with ciem?
doki81
if its just CIEM, the 1010 will do enough
oooo...where can i find it....i want to buy locally.. :(
i have the UE case for TF10 and my ciem can fit in...but problem is i need to bend the cable near the audio jack as i am using the oyaide straight termination :(
the case come with my UM mentor is also a bit too small...:(
Rubick
Jaben got sell. Think other audio shop should have it too. But I know Jaben do have it in stock.
Guan22
Soundwaves carry various sizes and colours for Pelican case
1010, 1020 & 1050.
Can head down have a look.
GotBetrayed
1010, 1020 & 1050.
Buy the fitear pouch at jaben. Can coil your cable within the pouch. An external compartment to keep your extra cable also.
doki81
what is the damage for the pouch? how is the pouch look like?:s13:
GotBetrayed
U try go jaben see. I use that instead of the default 1010 case that comes with 334. It's crush proof case, waterproof I think. Inside is designed to allow you to coil your iem in it. As for damage, it's 38 bucks from jaben.
doki81
erm..i google and found some picture...just want to know...comparing the 1010 case and fitear pouch....are they same size?
Techadd
hmm.. designed to coil cable around it, sounds ideal..better than 1010 case :D:D
frekedech
Get it HERE
Nice metallic case, using it with my fitear. Can engraved lim peh's name somemore :eek:
The catch is must ship from US through forwarders like HopShopGo or Comgateway.
doki81
Get it HERE
i have the case for UE but look like below:
the case is compact and nice but i will need to bend the cable quite a bit due to the oyaide jack i am using... for now..i need to look for a slightly bigger case...dont think i will go for the big UE case..and the small new UE case should be same size as per what i have~... :(
frekedech
Its taller and wider compared to TF10 case, having both at the moment.
DIXaRPBD
Still manageable and not too tight for me. How is it? :D
Taeyeonie
The FitEar pouch.
Price wise, please enquire with Jaben. IIRC it should cost not more than $30
Extremely durable and shock proof. Pelican cases are way too bulky for me.
frekedech
The FitEar pouch.
I saw this once owned by ex-owner of my 334 (He is using 435 alrd :eek:). I remember he mentioned he bought it at $40 from jaben. Nice case though, pretty solid.
