[NAS] Synology NAS owner club!
tnqhome
Join the club
Going tonight to buy the DS214play, wondering should i get Red or Blue Nas??
and should i get 2 HDD or 1??
leinad
Deluxe Member
Is it cheaper to get the HDDs yourself instead of purchasing as a bundle?
Normally, no. The retailers will typically give some slight discounts when customers purchase as a bundle.
Of course, if you're camping on Amazon or other online merchants for discounts, then it'll be a different thing altogether.
/Dan
Naoyuki
Thinking of getting a DS414 with 2x 2TB drives. Do you recommend using it with a SHR or plainly normal drives? Is there any advantages and disadvantages
mac_oasis
Hi All, Which 4bay NAS do you all recommend for home video streaming and also backup storage?
jtjt00
My previous ds212j with 256mb memory can stream 1080p without issue. If write speed of 80mb/s is fine for you, ds414j is ok.
Is the DS414J sufficient? Is the amount of ram important is mainly use for video streaming?
Vincent Tan
Bro, which model you bought? am also using 2 bay Buffalo LInkstation and thinking of jumping onto the Synology Bandwagon ha ha
Anyone can suggest a model for home NAS and mainly for movie streaming purpose?
Bought the DS1513+, previously using buffalo quad-linkstation.
OceanEleven
Hi guys, new to NAS. Any recommendation for one during this PC show?
Using it mainly for downloading movies, storing photos etc.
chercm
Version: 5.0-4493
(2014/06/04)
Change Log
After updating to this version, DSM will run data scrubbing on RAID 5 volumes and disk groups that were created in DSM 4.1 or earlier versions to improve the stability of RAID 5 volumes.
Fixed a security issue in the system kernel. (CVE-2014-0196).
Fixed an issue where all web pages could display "No input file specified" when the value of "Customize PHP open_basedir" was set to “none” or empty.
Enhanced the stability of iSCSI target service.
jas663
Hi all
I'm new to NAS, just bought a DS414 for home use.
Have some queries and hope to get some advise here.
I have 4 X 3T hard disk.
Should I install SHR or RAID 5?
If SHR, am I able to transfer my back up to other brand of NAS?
I intend to divide the space to 3 individual user (2T each) and a space for public sharing (for 3 of us, 3T).
1. Should I create user first then allocate them certain space? So will be only one volume.
2. Or should I divide it to 4 volumes? And allocate each volume for each one?
3. Can the volume be deleted in future?
Is there any Synology workshop that i can attend?
Thank you!
