Is yours installed with another launcher? Default launcher can't do that AFAIK.
Nope. How do I install the launcher?
Best as cctv5+lags due to too many user and i am using cloud tv seem good. Buy the 1 month trial for 4.99usd in case u have doubts
I am also seeing $8 option only. Can someone advise?it's 4.99 usd or 8 usd? I can only see the $8 usd option ...
Which app do you use to watch CCTV 5 if not from cloud tv.
Just take a photo with your phone and post here?
If you bought it from qoo10, you should be able to get support from them.
I'm using xiaomi box 1. last night tried to install vst on it. Installed snapea on windows and then connect box using usb. my snapea cannot seem to identify the box. it recognise it as android device. cannot install app at all.
any advice?
any advice?
the mibox should also run the snappea, once it run , run the snappea on your PC it shld detects
easier to buy an OTG cable, then use thumbdrive to plug into mibox via the OTG cable.
how to run the snappea on mibox?
U install snappea on ur desktop and once connect to mibox it will auto push to install snappea client on the mibox
i'm also keen in getting this device for world cup.
so to clarify,
I will need the jailbreak version + cloudtv?
that's odd, same app but diff packages?Chinese option have more Channels and under it it says USD$4.99 I dont have my phone with me as I did take photo of it to share with kakis on the TaoBao thread. later lunch time i upload so that GPGT
edited add pic
[/IMG]![]()
Himedia did bundle Imango which includes live TV, else dl HDPan , VST or MoreTV. these did can install on MiBox
edit: I recd alot of PM asking me if got lag or not. IPTV like its name is very much depend on internet and subscriber speed. traffic light does throttle speed and do take note. I am using MR 100mpbs for me I got lag now n den
Search for Gregory choo post as he did post togic plus file to watch astro/starsport free
edited add pic
[/IMG]![]()
