Streetwise
- Jan 1, 2000
Just to add, the $10/mth rebate is only for 12 mth. They say can call them again to extent the rebate after 12 month.
Yup, been there done tat
Zeltos said:Are you referring to the monthly $9.90 12mbps ADSL Singnet offer to existing customer?
What is this $9.90 12mbps ADSL Singnet offer to existing customer?????
http://forums.hardwarezone.com.sg/86257944-post16.html
i was on snbb 10mbps for like 2 years already =/
Just called 1688 this morning. After a brief chat with the CSO, was forwarded to retention dept. Was offered the same as above.
100mbps Fibre works out to be $31.50 monthly (5 mths waiver)+home line
15mbps ADSL works out to be $26.20 monthly (3 mths waiver)+home line
I don't really need 100mbps as I use internet for only a few hours a day. It seems 15mbps is enough for me. Hope this is the right decision.![]()
Hi, can I check for 15mbps plan, the plan cost $29.90? do you need to pay any quaterly subscription fees for the home line? Whats the charges for the outgoing/incoming calls?? Thanks!!
The only reasons for forcing mobile sim data down Internet BB users' throats is they hope you will exceed the 1GB and kenna the $70++ bill.
Kindly recommend an apps that can monitor and alert the 1GB usage and auto reset data usage every mth.
Others have answered u. Just have a question....if u feel telco is out to earn more from u...why don't just reject the offer....or just don't use since it's a freebie??
This is just like asking if MC Zoe Tay stripped neeked infront of u and temp u with CFM look and say FOC, what would u do?
Home line $10/mth rebate for 12 month, to call in again b4 12th month to continue for 12 months more rebate. I think incoming no charge, outgoing charges apply, not sure how much, but minimal only.
Ive received da mdata sim card, realised there's a number attached to it. Does it mean dat if i put it in my smartphone, i can use it to make/receive calls n sms. Anyone know da charges, or is it similar to prepaid. Will da charges be post-billed or need to top up like prepaid. Can't seem to find any info.
Yes, it is able to make calls but there would be extra charges to it, not so sure on M1 though. The charges would be billed to your monthly bill.
Ok thanks, fyi im wit singtel tho.
Just recontracted with this too:
-15mbps ADSL works out to be $26.20 monthly (3 mths waiver)
-home line $10 rebate
-7.2 mobile but won't be using it.
All I can say is, calling 1688 is a helluva nightmare...holy KERAAAPPP!!!![]()
