**Offical Oppo Find 7 thread**
Defyallodds
is the bezel of the oppo find 7a white made of metal? The black i has got dinged up just about a week after usage
Kuniyo
Hi guys!
I just bought a new Find 7a! Great to join the club! :)
Anyway, wanna ask all of you.. Where can I get extra covers/ batteries?
Also, is ColorOS going to be updated to KitKat 4.4?
roburn
If we based on 650k won in korea, wiuld b S $800.
However the last 2 experi3nc3 of LG, G Flex (~ 1k) or G Pro 2 (~900), chance of G3 at 800 would b low.
Not using RRP already.
G3 2 GB = 868
3GB = 928
Find 7 = ???
Still deciding between G3 and Find 7.
Leaning towards G3 atm
berber
where to get ah? Cause would like to get a spare white cover. =)
tried finding on taobao but don't know what to search it under. haha
Here ya go,
http://detail.tmall.com/item.htm?sp..._id=&am_id=&cm_id=140105335569ed55e27b&pm_id=
Seems like they have carbon fibre one now as well! :)
Hi guys!
Welcome to the club! :) For extra backplate and batteries would be Taobao. Casing and cover can get from Adix bro. With regards to KitKat, Oppo hasn't mentioned anything about it.
G3 2 GB = 868
3GB = 928
Find 7 = ???
Find 7 RRP $719, if you camp for used set when it's out maybe can get slightly cheaper. :)
Skyy
G3 2 GB = 868
3GB = 928
Find 7 = ???
Get both! I probably will do that! :s13:
But honestly, if u're a fan of AOSP, then F7 is the clear choice. Cyanogenmod has just officially started support of the F7/F7a so the 1st nightly has already been created and ready to download.
roburn
I flash PA since S2 and it's very likely I'll continue to use it for the foreseeable future. :)
aw1007
Some error to the updater script...it is tailored for Find 7 only,have to manually delete the assert. Otherwise u wont be able to flash it....:s22:
aw1007
kyleongwl
Oppo O Band.
Functionality includes a pedometer, a sleep monitor and an alarm clock. As well as the regular bells and whistles, the O-Band works as a phone locator, and a remote shutter so you can take photos with your phone from a distance
MRC
Oppo O Band.
Its out already here in china around 110 sgd i think.
