Unigine Valley Score Thread
artyboy
here's mine...
CPU: I7-4770K @ 4.2 Ghz
GPU: 2x 780GTX Ghz Edition
Core: 1359 Mhz
Mem: 3004 Mhz
Temp (Max) : 80C
Yureak
here's mine...
Core: 1359 Mhz
Mem: 3004 Mhz
Temp (Max) : 80C
solid! highly binned Ghz chip @ high clocks x2
win liao :s13:
but u on air? how u sustain such clocks? u sure got overvolt right
royfrosty
yours quite abit more OCed than hengheng's why his score only diff 60 points? :s11:
50mhz mah.
Iirc 100hz with 6-8fps and boost will equate around 125points. And iirc the cooling will plays a part on overhead to boost further which is why you pull ahead 600points.
hengheng220
bro lols you cannot calculate the amount of FPS and scores gain through amount of OCed differenced de. Cause its not porpotional like for every 100mhz you increase, you will gain maybe 5fps. is like the law of diminishing demand, it will keep increase until a certain point, it will either remain stagnant or drop. if it keep increasing, there will be no point in creating new cores architecture le ma, just creating better cooling solution.
Yureak
50mhz mah.
after u wc i recommend u flash a custom bios to enable increased power limits
artyboy
win liao :s13:
Yes on air, nope no overvolt done and I did not OC it further so they are at stock speed. I have 2 x 120mm fans blowing directly at the GPUs.
hengheng220
Come a joke for you all to laugh at lols. Don't ask me why i bother to do a benchmark on my lousy lappy hahaha but i just do
Yureak
oh haha valley the clock is inaccurate one... must use gpu-z or afterburner / precision to see your actual clock
shadow84
That fan at btm right is most redundant. Cooling ur psu cables ah? Shld jus remove it to prevent any dust intake.
artyboy
Hot air rises mah, so it just helps to push air towards the top where there are 3x exhaust fans expelling hot air out of the case. It won't help significantly but at least it does play a small part in airflow direction within the case.
Yureak
When u gonna go wc?
artyboy
When u gonna go wc?
Don't intend to bro, very happy with its performance liow. I didn't even use AIO cooling for my CPU when I had the chance as I still prefer conventional air cooling for less hassle. But I lost a slot space for my Creative soundcard due to the gigantic Noctua CPU-cooler and have to use on-board sound instead, that's my only regret :(
Yureak
ok la haha i dont feel much of a diff with how good onboard is nowadays
and i play hifi one. have sonus faber veneres
artyboy
Can tell difference bro, I find the Creative have more bass impact and sound more crisp than the on-board card. Fwah Sonus Fabers! I'm using Spendor & B&W.
