HTPC for Living Room
keichi_k1
Hi Bro's,
Looking to get a HTPC on a small budget for the below purpose:
1) Playback 1080p video and up to 4k if possible
2) Output to HDTV or 4k TV in future
3) Need HDMI output
Cost - 400 SGD or less
Do not need:
- Keyboard n Mouse
- OS
hengheng220
H81-hds + G1820~ $121
1tb Wd blue ~ $71
Crucial 4gb ~ $47
FSP Hexa 450W ~ $56
Sharkoon MA M1000 ~ $58
Total~ $353 build at tradepac
t258jgn
All the current motherboard (H87, Z87, H97, Z97) HDMI ports with Intel i3 & above support 4K Ultra HD
keichi_k1
Thanks All for the reply and currently only have the below rig config.
I saw a MSI Mobo config as well would that work?
1tb Wd blue ~ $71
Crucial 4gb ~ $47
FSP Hexa 450W ~ $56
keichi_k1
1tb Wd blue ~ $71
Crucial 4gb ~ $47
FSP Hexa 450W ~ $56
Wuld the below build be better?
G3220 + Msi h81i ~ $182
Kingston 4gb ddr3 1600mhz ~ $48
Wd blue 1tb ~ $80
Jonsbo v2 + Fsp 300w 80+ ~ $109
Logitech mk220 kb/m ~ $30
$449 buy @ pctheme. Ask for discount
Optional ~
Crucial m500 120gb ssd ~ $129
Kingston 4gb ddr3 ~ $48
Zotac gtx750 ~ $169 (Change to Jonsbo v3 case if needed a gfx)
keichi_k1
Also is there a difference if I pick a G3220 or G3240?
Since price difference is about 3-4 SGD.
keichi_k1
Reading the specs for H81I from MSI, it says it supports 4k UHD not sure if a discrete Graphics Card is needed or supported via the Mobo?
Only H87, Z87, H97, Z97 Chipsets
Supports HDMI with max. resolution up to 4K x 2K (4096x2304) @ 24Hz
Yo2020
for living room, u may want to spend more on a small case.
Alphas
It is pointless, hdmi spec do not allow 60fps in 4K, wait for hdmi 2.0.
