Any details on the above is appreciated.
Does Yamaha warranty covers WW?![]()
Hi,
I just bought a Home Theater Package YHT-299 3 months back. When I play my movies via HDMI ARC configuration, i.e. media player to Yamaha AV to TV (HDMI), the AV receiver will power off by itself after 2-3 hrs of continuous playing.
Is that a default time setting to power off the unit by itself? Or is it faulty unit?
Hi,
I am a newbie with soundbars and I am looking at the YHT-S401 and YSP-2200.. What kind of room or what kind of scenario you would use them?
Thanks in advance.
Hi YamahaSG,
I bought YSP-4300 2 weeks ago. Now there is intermittent pop sound ("dat") coming out of the soundbar. The volume of the soundbar will decrease after the pop sound and volume will go back to normal. What could have gone wrong?
Hi bro,
Can you refresh me where did you purchase this set?
I'm guessing you bought from our showroom right?
Thanks!
Hi, I went to the showroom on that day but was told they do not carry ysp 4300. End up I went Harvey Norman Millenia Walk to get it.
The pop sound (static sound) will happen randomly.
Hi YamahaSG,
I have the YHT-S401 Integrated Receiver.
The specs states that it supports 3D but when i connect my PS3 with 3D blu ray to it, the display shows nothing. when i connect my PS3 direct to display, I can see the 3D.
Connection is correct and I tested with the same short HDMI cable because I can watch/play regular 1080p via the PS3 thru the receiver.
Please advise.
Is there a problem with the receiver's configuration?
Hi,
I am interested in YHT-S401.
Can we test the sound system at Marina Square Showroom ?
Hi YamahaSG,
Please advise.
Hi Tan,
We would appreciate if you could try to reset Video Output Settings.
Read the link here:
https://support.us.playstation.com/app/answers/detail/a_id/262/~/ps3-hdmi-picture-problems
YHTS401 basically repeats the HDMI signal. If the source is unable to establish the HDMI handshake with S401 HDMI, the video will not go through also.
Let me know if you had tried so again.
Thanks!
Hi Tan,
Read the link here:
Thanks!
Hi Yamaha, can please recommend a 3.1 setup? Do I need an AV Receiver?
Essentially need to be able to:
1. Connect to (I) Tv, (II) set top box, (iii) blu ray player, (iv) turntable
2. Link up to Nas and stream videos
3. Switch from 3.1 to 2.1 at will (when listening to music)
Thanks!
