Normal GTX 780?
shadow84
Ok you ask me to change the side to AF120/140, is the side panel's fan that part?
Yeah.. That would give some air to ur gpu... But be warned, it will not drastically reduce ur temps.. At most affect 1-3 C.. The only way to bring ur temps down is thru water cooling.
memoriess
i can only buy a water cooling to my gpu? if so, how much will be a water cooling cost?
shadow84
Dun bother with water cooling or even AIO for ur gpu. Just stick to what you have. Your temps are still within acceptable range.
iAmBored
Wa hooted 780 dcuii oc for $730 last week, today 780 6gb out at $849.
Is the extra 3gb worth $100?
shadow84
If you can find a game that utilises more than 4GB of VRAM... Or u playing on tri monitor with 4-8x AA...
