The Spectacles Thread. - Part 2
joshuatan1984
Ok this is the best i could take. using 2 phones lolz....both side has it at different location due to the offset. Came in a zeiss ziplock bag inside, with a cleaning cloth, 1 gurantee certificate and 1 hard card with details of the lens, serial number and place where you got it from all in a name card holder.
Honey Amber
COOL stuff...looks nice, thanks for sharing...just an update on my case, so the specs shop called me today and say that they "complained" to the lab and they will send my lenses back for engraving and also lab will prepare the guarantee card for me..lol...another few working days of waiting...
jus a question, got fake zeiss with the logo engraved? haha
emailed zeiss yesterday night, and got a swift response today,
"All ZEISS lenses come attached with a guarantee card stating the lens type and cleaning cloth. You may want to check with the retailer if you did not receive the attached card and cloth. If it is a ZEISS transitions lenses, it should have a laser engraving on the lenses which is semi-visible."
popdod
my lenses oso Zeiss...also have the faint markings.
Great choice!!!!
:D :s12: :D
popdod
Any idea where to get the exact same specs as shown below. I like how round it really is!! Thanks in advance!
this one Oliver peoples have it.
Bras Basah next to escalator.
If you want an affordable version, no brand.
u can go to this "Jap" inspired spectacle shop at Marina Sq,
2nd level very near to Fourskin. Corner unit store.
you can't miss it.
;) :D ;)
popdod
open-uri20140506-3277-19ql6tb
Oliver Peoples Gregory Peck
open-uri20140606-20963-rxlgkf
Oliver Peoples Elins
open-uri20140611-3501-16iuuna
Oliver Peoples O'Malley RX
:love: :s12: :love:
noobzpro
Great choice!!!!
:D :s12: :D
Yea. Really night and day difference from crizal lenses. The lens is extremely sharp although degree is still the same. Contrast is better and also glare is reduced. Only thing i havent yet experienced is the photofusion, which i will get a chance to see how fast and how dark it turns tomorrow. I highly recommend it, also go for the duravision platinum coating its cost extra but its really good.
popdod
Real Men wear Zeiss Lens!!!!
:s12:
ahboy82
problem ish ahboy u neber believe in me ah... crosslink sweep got many colours, the red one should suit yur office wear, the rest of the colors too bright.
i want full black frame. i got a brown frame liao
not willing to spend above 500 for spec frame plus lens.
yeswecan
you can't miss it.
;) :D ;)
Thanks! Shall go Marina Square to have a look soon!
popdod
Which shop got wider range of Oliver peoples
Mandarin hotel level 2.
gotch 1 atas optical shop, gotch latest & wide range Oliver Peoples specs.
but prepare to get chop!!!
no 4 digit no atas. :(
Hard Atas Optical Shop Truths. :(
yodajedi01
I'm I think of changing a new pair for glasses.
I'll like to see any recommendation for half-rim titanium frame.
Lenses wise I'm looking at crizal prevencia :D
