GALAXY NOTE III ACCESSORIES
Jimmy38
Samsung Note 3 Smoothie Glass Screen Protector has landed
*** NO Bubbles
Easy to Maintain / Ultra lightweight / Smoothie and Clear HD / Rounded Edges Fine Cutting
Need help in software or hardware anyone can contact 93501388
Akai Ryu
Bryson
Is there any casing that is one piece casing which I can fit my ezlink card too? I'm using the samsung flip cover but when taking photos very troublesome as the flip is hanging..
Reserved
Hi I am currently using a uag orange case for my note 3, I am looking to replace it with something lighter & less bulke pluss easy to remove & has a good grip, please recommend me a case.
Caseaddict
Peeps, can kindly recommend which shop to go to for good range of spigen cases? currently interested in neo hybrid but would like more options if avail.
thanks!
Hi, try Nex level 2, very large range of Korean original brand mobile accessories. I buy mine there. Good luck.
thomasg68
Sedio Obex alotta problem :(
Ya, read about the echo and the earphone jack problems.
Really wanted to get this water proof case... the problems turns me off, plus the fact that I will need to remove my tempered glass sp to use it.
Paid too much for the sp. :p
Did u get the case?
Akai Ryu
Did u get the case?
nope did not...may get one from DX:o
or this
right now ziplock still best friend when i bring for outdoor adventure :D
agcken12
GALAXY NOTE 3 Ultra Thin Clear Silicon Air Case
- Simply Thin and Sleek
- Full Protection
- Light Weight
- No Watermark Great Handgrip
- Full Transparent
- Show off the whole beauty of the phone
any pic for the case??
