LG G3
myhairverypain
I using the stock player to play music. Got hissy sound too :( very irritating. I think LG G Pro 2 don't have this issue. :( previously using it like no issue.
Hmm... according to gsmarena the sound through headphone out is very clean... perhaps try a different earphone/iem?
wwh5210
1. actual set wont be as laggy. demo set is 16gb/2gb version and the demo video makes it laggy.
2. same as 1, actual set not as hot.
3. No way to adjust
Thx for the reply. All the demo sets r lock and there's no way for me to restart the phone either.
eijnaix
i read some1 mentioned in order not to have starhub apps upon inserting starhub sim is to factory reset the phone hor?
Yeah, i did just that....remove the sim card...do a factory reset. Than insert the sim card...a pop up will appear saying new sim card detected, do you want to restart ? SELECT NO !!!! Then all the stupid starhub app will not appear...
Andrewtst
Why should I care who she is. I only care whether I like it or not. I do not need others I do not know to tell me what I like. Lol...
...and when the 805 is here, it's time to upgrade (again).
Then stop saying people bashing. I only point out why I lost interested. Using the phone no need be that protective your beloved phone.
If I weren't using my G3 to type this, I would certainly hit the like button.
You can anytime switch to desktop mode and like it.
kennyg1969
This or use QuickMemo+. You can write or draw stuff on the screenshot before you save.
Quick memo has been the way for me from my G2, g pro, g pro 2 and now g3. What more, quick memo on screen button can be added.. it is way too easy for screenshooting
shager
I didn't like it that much =:p
twosix
Maybe you want to read carefully again. I said I will rather trust my own judgement than to let others judge for me.
pronto11
camera quality ?
hi guys..i'm not sure if it's just my set or..but i find the camera quality not so great. it performs poorly under low lighting and bright day light seems to be poorer than my samsung note 2 which was my phone i upgraded from.
any other feedback on camera quality on our g3?
i am not sure is it i must tweak some settings to make our camera quality better?
thks guys!
hiryu
Not sure if this has been answered before and if it has, I apologise for not checking properly.
Has anyone taken the battery out and then charging it on a wireless qi charger? Does it work?
I'm thinking of getting this for my wife and if the above can be done either through wireless or an external charger then I'll also get one more battery for her.
Thank you.
lth3388
I went to M1 on 27/6/2014 with my reservation email but was told no stock. Sent them email, until now nobody bothers to contact me. Time to say goodbye to M1, very very lousy customer service. They just don't care at all.
xRenol
Which branch and what time did you go?
garychengjw
Collected wireless charger.
The place damn ulu can. :s22:
IncTEh
Thank you.
confirm cannot work to just charge the battery without the phone using the qi charger. the receiver is on the battery cover, plus the circuit isnt made that way.
