LG G3
Casperz
mine is ok.. im using class 10 32gb sd card
I use a class 10 128gb sd card. When i tell the camera app to save my photos to the external SD, it take very long. When i take consecutive pictures in rapid succession, only the last pic is saved.
I think this is normal cuz saving that HD pix into sd card takes a while. When i swap back saving location to internal SD, everything is fine. So i dont think its a problem for me.
oakley
LG G3 do not support OSP!
Called LG tech support today as despite I've installed OSP on my laptop and PC, yet it can't detect my phone.
Apparently I'm told LG G3 do not support OSP!
What kind of BS is that... when older and lower end models do!
I can't select LG Software option after MTP options pop up on my phone when i connect via USB... :eek::eek::eek:
Computeron
my new love...
SteveAu
No issue for me... my pixs are stored on my sd card.. it is pretty fast to load up and delete.. Using a class 10 sandisk sd card, fyi
No wor...I set the pic location onto my phone storage not the micro sd card location.
skaade
They should implement this sia. If someone steal your phone, put your angry face there. Maybe they will return
no... a better feature is to snap a pic of the thief. apparently there is an app called thiefie which takes a selfie of the thief and u can see it when u locate your missing phone. :s13:
eijnaix
nova launcher with flatdroid icons (paid app)
nova launcher latest beta have android L animations and app drawer, folder etc.
softkeys are from xposed android L softkey module
Bro, I just installed Nova launcher prime and paid 5 dollar for it..... Where to use that flat Droid icon ah, I only see system and Kit Kat only
