The Spectacles Thread. - Part 2
shorty07
Oakley rubber cracks easily?...lucky sia i nvr buy. Theres a new model jus out with rubber. Very tempted to buy but decided not to as scared the neon green rubber will turn dirty.
Nakedtoes
how to avoid plastic frames from expanding?
all my plastic frames expand outwards.
what u mean by expanding?? u mean temples beside yr head started to get loose?.. u can use hair dryer to heat up the plastic joint above yr nose that part and bent the inward..
btw when u get a good frame the temples should not exert pressure on yr head.. it should "hug" ard yr skull for comfort
Citiguy
Few days ago can get the crosslink at $220 include lenses. Still NV buy cause Oakley rubber crack easily.
The temple rubber (ear socks) breaking easily is the main reason when I am not using Oakleys. The prescriptive frames used to have a lifetime warranty for the ear socks and the nose pads. Now, no more such warranty already.
Seannie
No way to avoid. Sad but true YOLO truths.
Get titanium frames can last longer without much expansion. This is due to material properties.
lyo&merly
whats the price range for oliver peoples frames?
the pair Cade Yeager wore in transformers 4 is a oliver peoples right?
llx384
$500+++. Sheldrake I last checked is $550. Varies from shop to shop and location of shop. There's a new shop at Marina Sq that stocks them. Went there the other day to check them out. Seems to be priced fairly.
I'm not an expert at identifying frames, but they look like either Fairmont or O'malley RX. But nowadays, so many brands are making similar frames. So it could be from anywhere. I feel that the specs he wore looked a little too expensive for his financial situation to be honest. When I saw it, I immediately thought it didn't make any sense. Just like what I thought of the entire movie... BAD.
shorty07
guess i made the right choice in not getting an oakley. that is till a nice metal one comes along. for now will stick to plastic. got an adidas, nice n light.
lyo&merly
marina square has a shop that sells them? is it the same as the one mentioned earlier? the one that sells japanese styled frames.
Nakedtoes
4 x boxes of Acuvue 1 Day Moist for Astigmatism - Daily Wear - 30 Lenses for $126 just arrive today from glassesonline.com
llx384
I did not read through previous posts, so I can't be sure. The $550 quote was from another shop.
I didn't pay much attention to the Marina Sq shop at first because it looks like a pop up shop! Wasn't expecting anything fancy or upmarket in there. It was only after I walked by and saw the brands 'Oliver People' and 'Paul Smith' that made me want to go check it out. I was looking for NDG at that time, but I'm holding off my purchase. Too many glasses. IIRC, they seem to have most models available. The staff wasn't familiar with the models though. I had to tell him which pair is NDG lol!
I have brand preferences, so I didn't notice anything else.
llx384
I am also looking for Oliver People (Gregory pack). Any recommendation of where to look for such brand.
Just read on the earlier post and came to know Marina Sq has Oliver People. Anywhere else I could shop?
Thanks
I got my Sheldrake from Paragon. I know there are some Oliver People frames at Holland V as well.
lyo&merly
What's the price range for oliver peoples? Seen alot of inspired brands around in the market. But I believe that quality is very different.
xReTaLiaToR
Hi guys. Does shop like spectacle hut offer lens cleaning service or something? There's hairspray on my lens, doesn't affect vision but when taken off, can see tiny specks of "glitter" on lens surface
springman
Hello all, will like to seek the advice of the experts here. The degree of my specs is around 600 and astig is around 200. Will I be required to purchase a 1.74 lense or will 1.67 be sufficient? What would be the price range? I probably will head to queensway to take a look and of course hope to hear from you guys first ... ...
-Zeora
Where is the best place to make spectacles at tampines area ah? Budget around 200-300. Thanks in advance.
Otherside
I'm clearing my wardrobe. Plenty of normal to luxury jeans for sale. Guess, William Rast and Habitual. Check my carousell or my threads.
okay, back to specs.
I don't know if anybody will suggest the same, but I think it will be cheaper to go JB to do your zeiss lenses. My friend goes to this shop at Pelangi Plaza.
yes, its cheaper in Malaysia. like 15-30%.
yongjing05
1.67 should be sufficent. Price abt 100 for 1.67 and abt 200 plus for 1.74
helanga
Try New China Optical Peninsula as their price are reasonable with vintage look and friendly uncle Tony...:)
