Itronics ITB100HD
ck1liang
I think I must give justice for the seller here.
He did sms back to me to do troubleshooting and even called me when all troubleshooting is unable to solve the issue and asked me to go one of their authorized workshop to check again before giving me a replacement device.
Had already feedback on how I felt but will not say much here.
Overall, exchanged was provided since it was proved to be faulty set and the current one is working fine (as of now).
Hopefully this issue will not happen right after my warranty end.. :x
XuiteShop
With Built In Power Saver for the New Premium HD 720P Itronics car camera, you can now do the settings of the voltage cutoff at your convinience in it's own individual software!
Qns: What is the Power Saver used for?
Ans: Its is a safety device that monitors your car battery voltage & terminates the power supply to the car DVR when the voltage is low to prevent over draining.
huihong
Whats the diff between the 2 batteries?
1. ITAB-100
2. ITV-90
Interested in getting ITB200L but not sure if really need the batteries.
Cus I'm currently using a very basic car recorder which turns on and records when start engine, then turns off when engine turn off.
XuiteShop
1. ITAB-100
2. ITV-90
ITV-90 is greater in capacity and able to charge faster and last longer in hours. Kindly sms me directly at 86608006 for queries as i'm seldom online.
Cheers.
XuiteShop
Itronics ITV-90 External Battery Pack is finally to be released!
Key Features:
* Rapid Charging to fully charge during driving.
* Able to combine up to 2 battery packs
* Limit Cutoff Voltage like a Power Saver
* Led status to show battery level & charging status
Special Pre-Order Price:
ITB90V: $180
Limited Stock ! Sms "ORD-ITV90" to 86608006 for Reservation today!
T & C
1. Strictly for Order directly from 86608006, Not applicable to Walk-in.
2. Limited to First 10 units only on First Come First serve Basis.
3. Deposit of $50 needed for Reservation.
4. Strictly for Promo Code ONLY!
5. ETA 10 July 2014
eurofunk
is it not possible to change the login is and wifi password for the itb100spw using iPhone? Cant seem to change the pw as don't see it on the ipass software at all
SimonLam
Moderator
Moderator
Cant recall if its the ipass software or in iPhone app.. you can change the wifi password but not the Wifi SSID
eurofunk
From the manual it seems to be changing of wifi pw is through the phone app and must be in android...I don't see any options to change wifi pw when connecting using iPhone.
Anything im missing? Using ipass black version 1.03
SimonLam
Moderator
Moderator
I let you know tmr morning when I get to the car.. I think iPhone apps can
Lafiel
keep getting continuous beep
even after changing sd card
what could be the cause
