Official ZenFone 6 Thread
BERSERK1980
the red one is quite chio!
same as the zf5 review unit.
noted on all the feedback.
will keep in mind when reviewing.
tentative review out next week.
now busy with tablets.
On a side note, i have uncovered a wakelock that is quite severe. 4000+ wakelocks in an hr. Its from one of the process under audioout and it occurs when you use the default music player. You can reset the phone to clear it but comes back whenever you use the music player. Alternative would be to use another player from the google store.
Jimmy38
Asus Zenfone 6
ULTRA THIN <0.3mm Smoothie Glass Screen Protector
Say Bye to Oily Surface and Sharp Edges
naglfar13
I understand that the Zenfone 6 is a dual sim phone. Which size of sim slot are we getting? Both normal sim or micro sim?
BERSERK1980
Dual micro sim and it has a spring catch system. Very easy to put in and also to remove. Dont need to worry about sim card reader pin being damaged.
mamboberg
Just wondering what is draining the battery life. Before I sleep I still have 90% but when I wake up left only 26%?
BERSERK1980
Definitely a rogue app,wakelock. Download better battery stats to find out which process is causing it.
mamboberg
And another thing, I switch off the phone to charge .. There's an orange indicator.. What does it mean?
Battery not fully charge? When fully charge it will change to green?
luigi545
Tried demo set of zf6 at funan IT mall concept store and there's a flicker on screen when activate camera for photo taking. Any owners have same issue?
BERSERK1980
Yeah orange for charging, green when full.
BERSERK1980
You mean there is a constant flickering when in camera mode? No such problem here. Was it on the latest firmware? I guess not.
modelinn
I have a new unopened red flip cover from Asus (original), wanna do a trade with the white back cover (non flip), anyone keen just pm me.. only new ones please..
kazxenon
Change the Anti-Flicker in the camera settings to the other value, the power Frequency in Singapore is usually 50Hz so set it to that value, if not try 60Hz
kreja
Is there any use for dual sim? one slot is 2G one slot is 3G right? so just use the 3G slot?
Kianzxc
zf6 looks good. But seeing zf6 size like abit too much. Anyway i had bad experience with asus. My padfone crack within 3mth..
Seriously dont trust their gorilla screen. No problem with other brand. But their 24hour delievery only at $299. Comparing with redminote to get it asap it will be atleast $220.
Zf6 user. Will u take a $199 redmi note or $299 zf6 if u have a choice again?
