I'm guessing bios. Ram speed set at lowest?
just a guess, but is the onboard intel gfx disabled?![]()
Gave this clue over at the blue forums so leveling the ground here.just a guess, but is the onboard intel gfx disabled?![]()
Hint - do try out your other chip and compare the idle VID values in hwinfo.Still no idea how you go so low. VID isn't it the same as Vcore?
Cause at stock settings it is at 1.09v.
The lowest I went was 4.2ghz that already hit 1.22v
Conclusion
Overall overclocking the G3258 on a H81 motherboard gave pretty good results. This article is not here to show how good an overclocked G3258 AE is (that’s already all over the tinterweb) but merely to show that you don’t have to pair this CPU with an uber motherboard.
Our results were very similar to what we managed to achieve with a considerably more expensive Gigabyte Z97X-SLI motherboard and given the lack of cores which is what holds the G3258 back, its simply not worth the cost of pairing it up with a high end motherboard unless you are looking for an intermediate solution.
Micro-ATX H81 with new high-endurance 5X Protection and multi-monitor support
ASUS 5X Protection - All-round protection provides the best quality, reliability, and durability
USB 3.0 Boost (UASP Support) - 170% faster transfer speeds than traditional USB 3.0
HDMI & DVI Outputs - High-definition Visual Enjoyment
New UEFI BIOS* – Friendlier, easier, and more intuitive with helpful info added
Network iControl - Real-time network bandwidth management
Nice!Hwalah. My 2nd chip was way better...
