The official Xiaomi Mi4 thread
kokitty
ooh... btw is it more worthwhile to wait for mi4, or should i just get a redmi note?
mi4 vs redmi note might not be a good comparison since the price point is quite different. Redmi note is a big screen phone for lower end users while mi4 is a flagship phone. You can probably buy 2 notes for the price of one mi4.
mi4 is definitely the better phone in terms of specs and design. If you're looking for a phone for daily usage, do compare it versus the flagships of the other brands and it should give you the best bang for your buck.
However, if you're just buying a spare phone... you might not need the best specs. redmi note would be a great consideration... In fact, do compare it against the other budget phones of its class...
caterham7
Quite different the 2, so depends on your requirements
Redmi note has dual-SIM and removable battery, likely mi4 don't have. Mi4 likely to have bigger storage, faster speed, more RAM
halocast
depends on yr needs,
if u are the type that do heavy stuff, like wanna play the latest games etc.. go for the latest mi4.
if u are medium or light user, i recommend note.
dual sim, screen resolution, all depends on yr need.
caterham7
halocast
the official spec is
- 801 dragon with 3gb ram
- 16 or 64gb storage
- 5 inch 1080p screen
- 13mp back and 8 mp front camera
- 3080 battery size with some kind of fast charge function
garychengjw
kinda letdown specs :s22:
halocast
Stainless steel frame, unbelievable craftsmanship & polish
- Snapdragon 801 chipset, 3GB RAM, 16/64GB Flash
- 5-inch 1080p display, extremely high color gamut (84% of NTSC range)
- 13MP rear camera, f1.8, real-time HDR, 4K video recording
- 8MP front camera, f1.8, 80-degree wide angle
- 3080mAh battery, quickest charging at 9V 1.2A (also supports 5V 2A)
i won't say its a breakthrough or something.
i would say its more of a refresh. now see the price :o
hope its cheap :p
uncle168
I think is about the same specs as mi3 except for the +1gb of ram
I think I go buy mi3 @ S$299 next week
keekeekee
Salapi
keekeekee
so far the extra 1gb probably doesn't do much.
4G will be the only reason people buy mi4 instead of mi3.
halocast
keekeekee
got difference
ram is more.
the screen got better color production
the construction is steel versus plastic
the camera is 8 for fron and back can do 4k recording.
the battery can fast charge
