ONEPlus ONE phone
Computeron
wa so now u back to G3? technically it seems to be a white balance issue from what I have read so im going to try flashing it for a bit and see if i can accept it. if cannot then i will let mine go. :s22:
ya... using g3... my int opo just reached me at home.. i'll c hows the screen... if not white then i sell away too.
Fellowes
u also by vpost?
DHL via CGW,
Btw anyone knows how to perform DLNA streaming to smart TV? Mine is Sony Bravia EX520, cause Samsung, LG thise major manufactures when you go into their gallery on the phone on the same house network, it will show a icon then tap it will display the photos or video on the phone to the TV but OnePlus One don't have such feature?
deathguise
DHL via CGW,
can always try chromecast =)
MRC
u mean the screen comparison or performance? if the yellowish tint goes away, i will be happier. let's see if the AOSP will do the trick. :D
edit: here's a pic comparison. left is OPO. right is LG G3
cLrTXfD0
Your opo quite obvious.
imacbie
eh, those yellows can be calibrated by tuning the hue, saturation, contrast, intensity and RGB one no? just need to find a good combination.
velato2006
wa... u like that say, i very scare wor...
urs is totally no whole screen yellow?
Okay i've taken a pic of my screen...hmmm, on the picture the bottom is indeed yellowish, but when i look at my phone closely on a white background..cant really see the yellow tint. So is mine also included??
Computeron
they called it yellow band of death.... which i believe is class 3.
opo screen has 3 diff kinds...
class 1 : pure white (epic)
class 2: whole screen yellowish (rare)
class 3: whole screen yellow + yellow stripe below. (uncommon)
imacbie
there is 2 kind of yellow here.
one is like what u are seeing, the yellow "Banding"
which is caused by, what pple said, the glue are not yet completely cured.
it can/will go away after some time of use.
the other one is the color tone of the display.
which is, to my knowledge, can be adjusted/calibrated to a certain extend to best of your preference, more warm or more cold.. etc.
in my opinion, dun dwell on it too much, they are not really visible unless you are looking at the screen displaying alot of whites.
lalalalalala
how do you sync your contacts to your google account leh?? so far what i've been doing is importing vcf file..
i did it on my iphone last time, not sure how it works for android though, but for iphone i press sync contacts then it started uploading contacts to my gmail account.
