LG G3
AnTiLooP
sorry bros. Can I ask which app to transfer whatsapp msg from Samsung S3 to LG G3?
You simply do a backup within the app itself... Then copy the whole folder to the sdcard. Once done pop in the SD card to the g3. Install WhatsApp. That's it.
AnTiLooP
Regarding color display:
Does anyone find that its pretty washed out? Ive compared to z2 and s5 and this fellow is really blend in terms of colors. Worse of cause is the m8.
Skyy
there's a setting in Accessibility that can zhng the colour contrast to make it like AMOLED. It's in Accessibility > Colour Adjustment
lao3hero
Miine does say improve battery life etc
stamina
Hi guys. I just got myself a G3. The windows transitions(close/opening of apps not as smooth as compared to my G2.Is G3 indeed slower than G2? Any idea why?
stamina
Yes!! Same thoughts on the fonts too.. Did you try other browsers?
Yes. I feel the same as i compared my G3 and G2 side by side. G2 Chrome fonths are smoother. But on other appss,fonts sharpness is the same as G2. So can the fonts in Chrome be improved in the next update? Hope so!
bermudas
I dnt see the post numbers in my chrome browser being displayed.how?
Nvm, just read this then.
altca4 wrote:
Nevertheless, if you are into snappiness do this:
-Go to Settings->Developer Options
(You have to click on phone build no. 7 times first to unlock the above option)
-change the transition animation scale, the animator duration scale and the window animation scale to 0.5.
stamina
Thanks.But why in general not as smooth as G2?
samson1
Well, one is running a higher resolution that the other. Needs more processing power. But once you changed the developer options, it will be OK.
GreenHorn
It won't be as smooth as G2 as the SD801 is powering 2K screen instead of the common 1080p (which it is supposed to be optimised).
Unless SD805 is powering the G3, it won't be as smooth as the other flagships.
