The Xiaomi Mi3 thread
kiawui
Upgraded to 4.4 now the web sms cannot use. And also cannot locate phone on Web interface.
Don't know what is wrong.
jlpk007
My gps was not working after upgrading to kit kat.
What i did was to re flash the firmware again(kit kat). And now everythings works(gps)
miloping
Hi anyone face this problem:
Sometimes when I type on SwiftKey I need to press v hard for the screen to register. I dunno it's lag or what.. Need to wait around 10-15 min before problem goes away.
I think this problem only happens in whatsapp but I not sure.
Any suggestions is helpful. Thanks!
Nakedtoes
U use what screen protector? Kitkat?
pv2008
Assuming that you purchased from Xiaomi Singapore, which MIUI build (in Settings->About phone) are you using? This is not the correct behaviour.
cokiee
a few posts down someone complained about the screen going mad after upgrading to the latest UI, detecting touches when there were none.
That happened to me yesterday. I kept having screens pop up and apps activated even when I had the phone flat on the table.
Restarted the phone (took me a few tries cause it kept detecting a touch on the cancel button) and it became better.
Has there been a fix?
pv2008
Was the phone being charged at that time?
miloping
Yeah I bought from Singapore
Miui build ktu84l,the developer rom.
If problem persist I am considering going to exchange, but idk if they will reject me coz I go install developer rom
miloping
Using the $2 screen protector from qoo10 lo.
4.4.3 kitkat (developer rom)
Btw is it common to have less than 800mb out of 2gb of free ram space? Even if I clear all not even close to 2gb..
kyleongwl
U will hv 1.2G when reboot.
Normally, around 800-1000 free
pv2008
Anyone encounter "no sim card" issue on their mi3 before? How do you fix it?
The first thing to check is to see if the set is genuine in the first place.
After that, are you using the SIM adapter supplied by Xiaomi or some 3rd party ones? They may not sit well in the SIM tray.
sHiErShAo
Already checked, is genuine. I am using xiaomi and 3rd party ones. Whatever simcard I put also can't detected.
