Xiaomi Redmi 1S thread
mingfreakrsx
Getting ridiculous :mad:
after installing the new update version 31, when I went into Sound to change notification tone, there is a pop up "Declaration and Impunity" Read the applicable terms carefully before you use the product.... Do you agree its requiring network?
Change sound setting also need to access network??? now they also collecting info on sound notifications used??? :mad:
my 1S shows a notification on the MIUI 31 Redmi 1S stable update, but after i went in the Updater app it shows I'm running the latest MIUI update..
trailblaze
anyone else having issues with wechat video call?
other end cant hear me but can see me while i can see+hear the other party.
reboot doesnt work...
yixiang1
Anyone tried ordering from the 29th July sale?
Is it true that xiaomi stopped providing the UK plug charger and microsim card adapter already?
Anyone can confirm? Thanks.
androidbot
Ditto. I'm waiting for the AOSP version for 1s.... MIUI is not for me. BTW, if I install another launcher, will I be able to have a proper app drawer? I really don't like the idea of dumping all icons onto the home screens like MIUI.
hey bro,
with regards to the launcher, yes you can have a proper apps drawer. I couldn't stand the sight of MI imitating fruit launcher and also felt in a state of disarray without a proper App Drawer. I've pimped up my 1s since with Buzz Launcher and am assuming other launchers should work fine too. I also had same concerns like many that 3rd party launcher may eat into the already limited RAM and slow or kill the 1s altogether but fortunately, that wasn't the case - at least for me. My 1s strangely feels alot snappier after replacing to buzz.
I must agree MIUI sucks (with a capital S) and memory leaks are quite apparent but with tweaking here and there it kind of stabilizes at some point. My RAM status runs anywhere between 130-406 and I do run into the "red zone" memory shortage icon every now and then but it has yet to disable any app half way through. Am rooted, so I've removed quite a bit of Google and System apps that I don't use or have replaced it with better ones from Google Play. On the side of caution, do take note removing systems apps is a very risky procedure you may end up bricking it altogether. So its a self-risk project.. :o
Another area of concern is the "so-called" MIUI security app. I've have partially disabled it cos am rather uncomfortable with it and am running another 3rd party security app which has better ability to control app permissions, ads etc. To sum it all up, 1s has too many settings all over the place not to mention, apps these days have similar settings which clash with system settings at times. 1s needs lots of tweaking as of now from OS to UI to proper RAM management. Until that gets sorted out we'll have to do with what we've got, for now.
Anyhow, here are some screenshots of my 1s with buzz launcher.
djzilch
Hey guys i got a spare redmi 1s if anyone interested, ordered a few for family but got extra one, item is with me at city Hall area
PeasantBeing
Please share the 3rd party security app. I hope it doesn't take up too much RAM also. Thanks!
kopi22
hey bro,
Very nicely done bro!! Maybe I give it a shot as well. BTW, all I need to do is to install the Buzz Launcher right? The underlying rom is still the MIUI? No flashing of other rom require right? And can I set the Buzz Launcher to be the default launcher going forward? Please share how can I do that if that's possible?
Thank you very much!
androidbot
Thank-you and your welcome. Yes, just install buzz and your underlying rom will remain as MIUI. You can revert back within seconds to MI launcher via (settings > display > default launcher) if you do not like Buzz. Ultimately, you may just unistall it like any other app. In fact, if you uninstall buzz you will automatically fall back on MIUI launcher. And yes, you can set buzz as default. Just play around with the settings and see if it suits you. Do share screenshots of your invention if you decide to keep.
Hope it helps.
EDIT : No root required.
kopi22
Hope it helps.
Thanks! That's very helpful of you. I will give it a try tonight.... Hope things will look better with my 1s. :s12::s12:
St00ky
hey bro,
the lock screen wallpaper is nice. where to find it? haha
nannoid
Anybody wants the following FOC item(s)?
1) Redmi Rechargeable Battery [Brand New]
2) Redmi Battery Charger [Brand New]
3) 2x Redmi Screen Protector (Anti-Glare) [Opened, 2 Pieces remaining]
4) Redmi Soft Case (Black) [Opened, Used]
Self-collect (first come first serve)
Picman55
Hi, can i have the Redmi Battery Charger?
I can self collect from you....
Darkness_Eye
Hi bro can i have the battery and screen protector
I can self collect from u :o
haiz2006
Hi I have few questions for redmi 1s, am holding it for few weeks already...
1) what is rooting? How it benefits my phone and how it helps with freeing the ram? I already download some app that can clean up ram
2) anyone have serious issues with the data usage tracking function? It's just don't sync or reflect same data usage as my Singtel app which I have, obviously Singtel should reflect the correct data usage. 1s I kept getting over limit no matter how I changed the peak limit? Is a bug?
3) how to transfer my apps over to SD card? I always see my SD card not used but instead my phone 1s keep all the stuffs!
yixiang1
sorry to ups this again.
anyone received the latest order yet? Appreciate if anyone can share here. THanks.
mingfreakrsx
1) Rooting gives you more functions and features that are not available for non-rooted phones. It also provides you functionality to delete preinstalled apps such as Google apps etc.
2) I myself is also on SingTel but didn't get the over limit bug. You might want to try setting your data limit again by going to: Security app -> Data Usage -> settings(top right) -> choose your SIM (SIM1/2) -> Mobile data limit. From there you can set your data limit and data usage warning level and usage cycle reset date.
3) You need to root your 1S to move your apps to your SD card.
