LG G3
skaade
Sorry bro, basically it's saying 'The device is suspected in rooting. Software update is not available for rooting device'.
Update: I saw previous post that others also encountered this issue, I will try the wired method and see if it's able to upgrade. Kindly ignore this pot. Thanks.
:s8:
not about wired or wireless. set your dpi back to original and update.
anyway, best dpi that i have tested is between 530 to 540.
skaade
Strangely the amazon store app and the amazon app store app both don't appear in my google app store search. Had to install as an apk.
same issue as u. cant find UP by jawbone and photofy in play store on g3 but can find it on my Oneplus. havent researched for fixes but i will try to side load the new play store
IncTEh
I can find leh.. Have to updated it to the latest firmware? I think it fixes these issues.
skaade
yes updated to the latest one, still dont see it. very weird. want to reset but need time to back up my messages.
Off topic a bit, but how to back up wechat messages? :)
vibranze
Thanks bro. I managed to update the firmware to 10G via LG PC Suite, re-rooted with purpledrake-lite, uninstall all LG apps, change dpi to 540, tweaked via Tweaksbox and good to go now. Speed is definitely faster, snappier than before, especially show running apps. SOT is also better.
vibranze
You can backup wechat messages to Tencent's cloud, IIRC it will remain there for 1 week before gets deleted.
Cheers.
skaade
but in future, remember that its DPI issue. if not you have to do all the steps that u just mentioned again which is very tedious! :s22:
vibranze
Wohoo, I managed to install the custo recovery followed by CrossBreeder, now check entropy result is 4096. Lag free FTW! :p
skaade
True that this phone got overheating and battery issue?
not true. my last sony z1 had an overheating issue. this phone only heats up when i play hayday or surf for 1 hour ++
battery issue? What do u mean?
twosix
No, it is not just dpi issue. Mine version 10b, did not change dpi but towelroot rooted. Update to 10e got the error the the phone is rooted.
