(Storage) SSD Discussion Thread
xtreme84
Usb3 is not enough. Make sure both the enclosure and the host supports UASP.
The immediate benefits is saturating random access speed, that is what SSD is really superior in. Sequential access is better but hardly utilized most of the time
Ah... Thanks for sharing, that's something new to me.
jeff79
Is it normal for my 7 months old intel 530 to have 2 re-allocated sector count and 1 program fail count?
jeff79
First time using ssd. Do re-allocated sector count and program fail count need to RMA?
speedster4005
As far as I can remember, for Crucial, I was asked to monitor the count if it increases in a week or so (I can't find the mail From their CS anymore). When it did, I was asked to RMA it.
You may need to contact the manufacturer about that.
Apparatus
xtreme84 said:
Probably just put it in a USB 3.0 external casing since that interface offers the highest transfer speeds. Besides, most SSDs still have not reached the theoretical limit of the USB 3.0 interface yet.
So can I say I should be looking for an external USB 3.0 to SATA III (6Gbps) enclosure with UASP support? Any reliable brand available here to recommend and place to buy?
I'm thinking of getting it for the SAMSUNG 850 PRO 1TB SSD
adrianlee
Kingston SSDNow V310 960GB SSD
Kingston SSDNow V310 960GB SSD Review - Legit ReviewsKingston SSDNow V310 960GB SSD - The Almost 1TB Drive
Crucial MX100 512GB SSD Review
Intel SSD DC P3700 1.6TB PCIe NVMe Enterprise Review
SanDisk Extreme PRO 240 - 480 and 960 GB SSD review
SanDisk Extreme PRO 240 - 480 and 960 GB SSD review - Article
Toshiba Q Series Pro 256GB Three-Drive SSD RAID Report
Prof. Utonium
Few hours back heard clicks coming from my ultrabook.
2 years old and dropped a couple of times after falling asleep from bed. Suspected it was coming from hdd, did a test and showed warning. Thinking of switching to SSD.
Can I buy any SSD from amazon? Since it is ultrabook, I am not sure if any SSD can fit it as compared to a laptop's. Not looking for high storage SSD since I have external HDDs that I always back up to.
Need to get it fast before kaput...
zhouxiang19910319
Hey. I'm not a pro in this notebook area
But just wanna remind you if it's an ultra book, is it possible to upgrade the storage ? Aren't ultra books got everything sealed in ? Like a MacBook Pro retina or sth?
Prof. Utonium
No such thing as completely sealed, it can be disassembled. For notebooks/ultrabook, common household screwdrivers can be used.
Smartphones a little bit harder due to unique tools required.
vcrpex
Hi,
My current system is about 5 yrs old. Using amd athon x3 chip, contemplating of getting a ssd to try out. But being an old system, is it still worthwhile to get the ssd?
Hi,
Of course it's worth if it got support sata. Mine 5yrs old laptop is running Linux mint on a 64gb ssd
eclairily
Need some advice here~
Acer Aspire 5755G-9471
Processor: Intel Core i7 2670QM 2.2ghz
Graphics Adapter: NVIDIA GeForce GT 540M with 1gb dedicated vram
Display: 15.6 inch, 16:9, 1366x768 pixels
RAM: 8GB
HDD: 640GB
Is this worth a SSD upgrade?
TIA!
SimonLam
Moderator
Moderator
Going from a normal hard disk to SSD will bring improvements even to older laptops - I say go for it if you keen to keep the current laptop and extend it's useful life
eclairily
I am not sure if its the fact that its been a long time since i switched on my lappy or it is getting old. Now the startup time is cui and it is rather lag despite defrag. Wondering if ssd will solve the problem. Hm. Thanks for ur input!
a562140
from hdd to sdd is the biggest value for money improvement you can make today.
xtreme84
I'm pretty sure an SSD will solve your problem. Do a clean install on your new SSD and you're good to go. An SSD also hardly requires any maintenance at all. I used to have to run defrag on my HDD, do a clean installation regularly, etc, just to make it run more quickly. But those don't help very much and a clean installation also is rather time consuming.
Indeed, I've encouraged everyone around me to switch to an SSD as it offers a very significant performance boost. Once I switched to SSD, I never looked back. I even swapped out the HDD on my work laptop for an SSD at my own cost. Improves my productivity as well.
herzog21
what's the best 240/256gb ssd out there currently? so many are out there flooding the market that i am spoilt for choice.
thinking of hooting from amazon. anyone can recommend?
