The Spectacles Thread. - Part 2
Windowlover
Interested in Ray Ban optical 5285 model, anyone with shop to recommend for value for money ?
On line some glass frame is selling, it is possible to buy and let optical shop to fix up glass instead.. :s22::s22::s22: plan to get one for far sighted use..
WoShiNiDeCrone
anyone gt any shop recommendation to make rayban sunglasses with degrees lenses....my usual shop quoted me $300...looking for lower prices
Webbyboy
Zeiss 1.56 vs 1.60 got alot of difference anot? And anyone heard before with Clarlet coating/tech?
wwarrior
hello guys, thought this thread would be the best place to ask the following question :o
do we really need spectacle hooks during NS? i bought a pair to fit on the specs and the hooks eventually gave way and split into half at the top. the end of the specs are thicker than the other parts of the specs.
Aegagropila linnaei
Not really needed unless your spectacles is so loose that it will drop/slide during movement. In that case, you will definitely need hooks. My boyfriend's spectacles are the loose kind so he used hooks during his NS.
kingcarlos
just got a pair of specs from Richard's Artelier. Pretty good service and some nice niche brands.
Aegagropila linnaei
Is it worth it to get Zeiss individual single vision or Zeiss single vision superb? The individual SV is labelled as their best lens but I read some reviews saying that they might mess up your vision. Anyone have this pair of lens?
If it's not worth it, then I will get the SV superb instead.
Windowlover
Looking for Ray Ban RB5299 - 2000, anyone know what it this pricing like and where can I view it.. need one for work... or any recommendation like this shape type. :s22:
wwarrior
not loose, i usually put my specs on and forget about it :s13:
in that case i won't get another pair of hooks. thanks :)
sogatda
hi guys, how should i go about choosing the type of spectacle lens for my eye type? based on 1 example from capitol, there are at least 8 different brands of lenses!
or maybe just list the top few famous reputable ones that are most value for $ thanks.
Capitol Optical
dominicwor2
Capitol Optical
hoya ftw. otherwise zeiss if you're feeling generous with ur moolah :crazy:
flea007
Best place to buy Tag Reflex series
Wondering if anyone have any feedback on where to buy and price, and how the frames take basic wear and tear?
sogatda
are they similar to seiko lenses, which try as much as possible to maintain your current eyesight degree as much as possible and anti-astig?
thanks for the recommendation though!
Kenneth
May I know where can i find the largest range of Nike Vision optical specs? Not shades.
thanks.
