Xiaomi Redmi 1S thread
zenify.me
When recording video with my 1S, there is a blue spot at the top right hand corner of the video. It is particularly obvious when recording in darker area, probably due to dust stuck in the lens. I have to watch the video on my PC in order to spot it.
Not sure if it is worth bringing down to the service centre. Have a few questions that hopefully the laojiao here will be able to answer.
1. Will I get a 1 to 1 exchange on the spot if I bring to the service centre?(i.e., no need to wait for tech to repair my defective set.)
2. If I were to get a exchanged set on the spot, can I assume that it will be a refurbished set?
3. Should I expect the refurbished set given to me to have cosmetic flaws or damage caused by the previous owner?
Sorry ah, I know I am being fussy over a $169 phone. :s22:
androidbot
If it really bothers you then get it repaired while under warranty but be prepared for other problems to crop up after repair not 100% but yes it can and does happen to all phones after repair.. Depending on the problem, they may just replace your camera module or the whole motherboard and possibly, to a refurbished one.
1) Phone is usually taken in as repair and not 1-to-1. This is the practice of many phone makers. Accessories, qualify for 1-to-1 exchange (e.g. battery, earphone, charger, powerbank, cable etc..)
2) I highly doubt they will do a "on the spot" even for a refurbished set. Anyway you can try.
3) Usual practice is they will change the plastic exterior - which is very cheap for them. For Samsung Note 2 exterior plastic frame costs about $23 to change this was quoted by a friend who deals in 2nd hand phones. Of course, customer will be quoted higher lah.. :o
Good luck
androidbot
Was on version JHCSGBD27.0 - with native root did a unroot and immediately after received OTA for V35.
As of now, the main thing I have observed is the network bar is more stable and strong. With V27 (under StarHub) I could only get 1 bar and max 2 bar in my home. Now with V35 full 5 bars and perhaps 4 bars, intermittently.
Strangely, the date bug still exist. Charging, battery depleting, snappyness and heat emitting or lack of it remains the same for me as V27. Which is not a problem. Still lacking in memory management though.
Native root works on V35 without a problem. How I wished rooting and unrooting be this simple for all phones. Root and unroot within 2mins. Simply, love it. :D
mingfreakrsx
TD-LTE Redmi 1S coming this Saturday in China ..
RMB699 ~ SGD$141.97
MTK6582 1.3GHz quad-core, 8GB flash memory/1GB RAM. MIUI V5 based on Android 4.4 . 2200mAh Li-Ion battery. Single SIM.
http://www.mi.com/hongmi1s4g
zenify.me
ArcticCheetah
Lucky it is DOWNGRADE from Snapdragon 400 to MTK6582.
I feel better already :s13:
Not that I care for 4G LTE
My guess is that they had to downgrade the processor to pony up cash for the LTE License...:s8::vijayadmin:
androidbot
4G is really not up to par in Singapore if you ask me.. almost comparable to 3G when you compare it to other countries. What 4G is truly capable of here is in draining more power out of your battery. Put 4G with a small sized battery will only result in a disappointment. Only consolation would be that 1s has the ability to swap battery.
Not to mention, you need more RAM for you to actually enjoy those so-called, fast and furious uploads and downloads, opening multiple browser pages etc..
What Xiaomi should have done is increase the RAM instead of pushing the already over-worked phone. I would have disposed my current 1s at the speed of 5G if the new version only had more RAM.. :s13:
zenify.me
Redmi 1S First Impression
If you have not heard about it, there is a new competitor in the Singapore mobile phone market that is giving other mobile phone manufacturers a run for their money. This competitor is Xiaomi, it was founded in China and has expanded their business to Singapore, Malaysia and India as of today.
Xiaomi specialises in delivering products that offer more bang for your bucks. The Xiaomi Redmi 1S, which is retailing at SGD$169 offers a set of similar hardware specifications to the Motorola Moto G, which is retailing at SGD$318. I have made an online order for the Redmi 1S from the official local Xiaomi website earlier during July and here are my thoughts of the budget phone.
Size comparison between Redmi 1S, iPhone 4 and iNO One.
Fingerprint resistant back cover of Redmi 1S.
The back cover of the phone has a matt finishing that makes it fingerprint resistant but makes a creaking sound when pressure is applied onto it. The size of the phone makes it hard to operate the phone with only one hand, probably not the best choice if you plan on typing text messages with only one hand.
The back facing speaker is a hassle when you lay the phone flat down on an uneven surface such as your bed or play games that require you to hold the phone horizontally. The speaker tend to be covered up, making it sound muffled.
Stretching the Redmi soft case with a micro USB cable.
The soft case I bought for the phone seems to fit too snugly, after I fitted the case on it I tend to trip the power button accidentally. My solution was to stretch the "buttons" on the case itself with a micro USB cable to solve my power button problem.
The MIUI(MI User Interface) OS that is installed on the phone is user friendly and very similar to the iOS interface, for those who prefer using the stock Android interface can download Nova Launcher from the Play Store to replace the default MiHome Launcher. You will need to go to "General Settings", "Display", then "Default Launcher" to change the launcher after you have installed Nova Launcher.
For those of you who plan to install a lot of games and applications or take tons of pictures and videos with your phone, the 8GB internal storage of the Redmi 1S is probably not enough, out of the box the phone has only around 4GB of storage space available. The storage capacity can be expanded with a micro SD card. However, this does not solve the storage space problem as the games, applications, pictures and videos taken by the MIUI camera application are stored to the internal storage by default.
The solution to the problem is to install the XExtStorage application on your phone, what this application does essentially is change the primary storage location from the device's internal storage to the micro SD card you have inserted to the device. However, you will need to root your device before you can install the XExtStorage application.
Q: How do I root my Redmi 1S?
A: [works with 34/35] How to get native Root for Redmi 1S and how to UnRoot again - Redmi 1/1S - MIUI Official Community
Q: How do I install this XExtStorage you speak of? I cannot find it in Google Play Store.
A: Redmi 1S: Save your Internal Storage using XExtStorage - Redmi 1/1S - MIUI Official Community
Q: What kind of micro SD card should I get?
A: As long as it is not a counterfeit card it will probably work fine.
Comparison of Different Storage Type
Redmi 1S Internal Storage
Kingston Class 4 32GB Micro SD Card
Samsung EVO Class 10 32GB Micro SD Card
Q: Why does file transfer fail so frequently when I try to copy files from my PC to the Redmi 1S and vice versa?
A: The driver for the phone is probably not installed properly on your PC. Plug in your phone to the PC, navigate to "CD Drive (X) XIAOMI" and use the "Setup.exe" executable to install the Xiaomi desktop client. The driver will be installed together with the client.
Q: The desktop client is in Chinese and I do not use it at all, I only need the driver for the phone!
A: You can install the client then uninstall afterwards, the driver will remain installed on your PC even after you uninstall the client. If you are technical enough, you can choose to download and install the driver files using Device Manager. Once it is installed, it should show up as "Xiaomi Composite MDB Interface" in Device Manager.
Q: I don't use Mi Cloud at all, can I get rid of it?
A: If you are rooted, you can install ROM Toolbox Lite from the Play Store and freeze "Mi Cloud framework" and "Sync with Mi Cloud" using the app's built in App Manager.
edcruz
anyone has the quick url to add xiaomi 1S to cart?
and also the powerbank?
thanks!~ :s12::s12:
pooopy
I have this problem with music player/radio
every time I play it and then I use other apps
it will automatically stop playing after some time and I have to launch the music player/ radio again
can't seem to find this problem in xm forums
any one can help me ? :(
mingfreakrsx
encountered once of this issue but didn't encounter now, i suspect it could be due to the low RAM memory..
