XiaoMi MiPad
Just Me
Just one small query for Mipad owners.. do you really have 16gb for installation of apps and games? Chinese tablets tend to mislead people on this point.. In the past, all the MIC tablets I've seen advertise 16/32gb but only 1-2gb of internal space is available..
laughingPANDA
I don't think xiaomi has that same app restriction like oppo does. Correct me if I'm wrong :s13:
And yes that restriction of how many gb for apps is really annoying :s12:
Just Me
Hi, you have the mipad? Can show a screenshot of the storage under settings?
garychengjw
16GB model should be around 13.46GB usable.
garychengjw
Thanks but there's something I don't quite understand. Your internal memory shows a total of 13gb yet you have 41gb worth of videos and pictures.
Because i've 64GB memory card inside.
I assumed it calculate together.
skaade
i have a mipad 64gb white from china that i am helping my friend to sell. she couldn't wait and got herself another tablet. it's been opened up to check and verify it's authenticity but not used.
also have 2 x tempered glass screen protectors to sell off.
if anyone is keen, please PM me. :)
porcu
Which do you like/prefer more for tasks such as Web surfing and reading? iPad Mini or MiPad?
Right now, I have an iPad Air and the MiPad. I'm thinking whether or not to get the iPad Mini LTE(this year's one of course) for outside use. My iPad Air is LTE enabled and the MiPad is wifi-only. I would love to bring just my MiPad out and keep my iPad Air for home use but it can't use my data plan, so I still have to lug around my iPad Air :( if it supports LTE, I definitely will not be getting this year's iPad Mini. Anyway, I have a few more months to think about it :D
Still ipad mini r feels lighter and also mine is LTE so able to use data.
Also, the screen is brighter for iPad outdoors.
Just PM-ed you, regarding the tempered glass SP.
Yes yes, even though I have an iPad Air and now the MiPad, I'm still considering getting this year's iPad Mini. Reason being, I'm switching to an 8 inch tablet for outside use. iPad Air is a little too big to carry around, I'm going to leave it for use at home. The MiPad is perfect for this, however, it doesn't support LTE and my 5gb/month data plan :( So I still have to bring my iPad Air out :s11:
I think iPad Mini still has a couple of advantages over the MiPad
1. LTE
2. Better build quality and design
3. Apple's ecosystem (App Store, iTunes)
4. Much much better ecosystem of accessories available
MiPad's advantages over iPad Mini
1. Much more storage and flexibility when it comes to storage. With 64gb model, you can expand it by up to another 128gb with a microsd card.
2. Much much cheaper than iPad Mini. Even if you get the 64gb model and a 128gb microsd card(which is not cheap), the total cost will still cost less than an iPad Mini Wifi-only 128gb
porcu
Another advantage of mipad....
Having the K1 nvidia chipset, when u play games like Dead Trigger 2, or any games that supports nvidia and OpenGL API , u will see huge differences.
For eg, more textures, better water or lightning effects and also smoother frame rates.
I tried Dead trigger 2 on iPad add mipad, and it's a huge difference. Should go try urselves.
