Fujitsu Laptop Users Thread
fone
I bought the wrong modular bay battery.
Anyone know is I can mod my laptop (maybe with another modular bay card) so that I can use my new modular bay battery? Assuming they have the same sockets, as I did fully dismantle my old S7021 but not my still-functional E8410.
joshua__lim
Has anyone heard about the sound card socket problem affecting SH560 that causes windows to hang? If yes, did you manage to fix it? Thanks for sharing.
maggieme
lappie died...
hi anyone can help? i couldnt power on my laptop! and i dint managed to do any backup? should i send to fujitsu service for 80 bucks or anyshop in sim lim could do? if yes any good sim lim shop to recoomend? pm me pls... many thanks!:s11:
saidean
My colleague's Fujitsu notebook S6520 has refused to boot up. No POST, no hdd whirring, no fan sound. Pressing the power on switch does show the blue led for power, but this is quickly followed by either the num lock led blinking away, or the scroll lock led blinking away.
Has anybody encountered this problem before?
I removed the battery and retried power up. No luck.
I removed the 2 sticks of ram (2x2gb) and reseated them. No luck.
I removed the hdd and tried to boot. No luck either.
Any ideas?
naddelgum
Please help!
Hi guys, I'm new here and not much of a techie so please bear with me. I have a Fujitsu S6520N with vista 32-bit, 4G RAM.
system has been a bit laggy with startups, reboots, waking up after sleep mode for a while but the real trouble started yesterday.
laptop's gone without reboot for a few days i guess, i usually leave it on and put it on sleep when i'm away. so yesterday i had IE on with lots of tabs open, a couple of Word docs, itunes, skype. i noticed that physical memory was running high at about 70-80% so i closed some tabs, closed Word, etc. still it was really high and at some points i got error messages/out of memory messages.
then as i started to look into the problem i realised that explorer.exe was using up lots of memory like 40-60mb and later i noticed svchost.exe and dwm.exe taking up lots of memory too. i tried to run a virus scan but once it got to explorer.exe, the system hanged. i tried rebooting and force quit a few times cos the same thing kept happening.at first it wouldn't load the welcome centerupon startup though the desktop loaded fine (clickable n everything). sometimes it wud just load the frame of the welcome centre with a white space where the text n images should be. n now it wont even load anything upon bootup.
i'm on safe mode now n i tried running the scan - same issue. hangs at explorer.exe.
can anyone tell me what the problem is?
this is most definitely not the first time i've had issues with my computer. it's crashed on me a number of times for which i've had to send it for repair at the uni vendor as well as privately while i was abroad.
thanks in advance guys!
joshua__lim
perhaps time to reinstall windows. and maybe downgrade to xp. ;)
HaroBoy
reformating S7111 Vista
Hi guys, really need some help here.
I own a fujitsu S7111 and I'm getting the dreaded blue screen. Wanted to reformat it, but i do not have the recovery CD as i did not create it when i first bought it.
Can anyone advise how can I obtain one or exactly how do I reformat the laptop?
realli help!
littleboi1220
i've using s6420 for a couples of year now, had not much problems abt it but recently i face some problems with the startup. when i put it to slp or hibernation, it wouldn't start up. i need to switch it off then boot it up again, any1 can help?
cheeyt82
fixing this fujitsu s7211 laptop for my friend. has anyone changed their cmos battery by themselve before or any shop to recommend to change cmos batt?
cnt
try google for service/maintenance manual see if it is ez to change :s42:
Jolstel
Hi all, I'm currently using a lifebook a6120. I accidentedly spoil water onto e laptop and right now it can't be on. Is there anyway to revive it? Or must I send it for service/repair?
jtjt00
Fujitsu SH530 Laptop
Anyone know how to remove the back cover for Fujitsu SH530 Laptop? Already removed all screws and yet still unable to remove the back cover.
fokgola
guys anyone know why my fujitsu l1010 cant read a 2.0 compatible usb 3 external harddisk?
sashaBEAR
any laptop to recommend for one who commonly uses AutoCAD, 3D Studio Max, Photoshop and Illustrator? :)
kityip
Hi any Fujitsu LH531 users here, may like to check can the DVD-drive burn "Lightscribe DVD" ?
Thank you :D
gohks
Windows Vista Business Recovery Disk for S6311
Hi all,
I am looking for Windows Vista Business Edition Recovery Disk for S6311. Do anyone has a copy? If yes, can I borrow it from you? Need to do up the laptop and use it as student notbeook for primary school kids.
Regards,
KS
ideatalk
hi, i had just reset my fujitsu l1010 to factory default and installed some new programs....before i start using i would like to create a backup so that next time i will able to save time in reinstalling the programs.
Can anyone advise on how i can do the backup of my entire c: drive?
