Sineoji 1800 mbps MIMO Homeplug benchmark against Sineoji 600 mbps homeplug from fibre ONT to bedroom on Speed Test.
Mr. Sineoji
I plan getting 2x PL600EPG and PL500EW.
Question is when I plug PL500EW into the power socket will both PL600EPG fallback to AV or PL600EPG will still communicating using AV2.
Because the speed between PL600EPG is crucial. I do not want PL500EW to degrade the speed.
Here is the planned setup
TL1043N
-> NAS
-> PL600EPG
PC1
-> PL600EPG
All wireless device(Speed not important, range does)
-> PL500EW
I have TL-LinK TL-WPA281 300mpbs with wireless. If this works with PL600EPG(without slowing down the speed between PL600EPG), I dont need to buy PL500EW.
Also, any idea of the price for PL1800. I willing the wait if the price does not defer to much.
Eagerly waiting for PL1800E price..
Luckily my spouse stopped me from doing the wiring works in my 6 years old BTO flat, this will solved my wifi solution in my master bedroom period once and for all.
Thank you, Sineoji.
The setup below is almost the same as mine just that Im riding on a different ISP yet it able to attain the subscribed speed up/down exactly from my Asus router in the hall & connected PL1800E (trial complementary of Mr Sineoji) at my master bedroom.
My current powerplugs I am using are PL500EW (connected to Asus AC66U) & PL500EP (connected to Asus AC66U) and tested it really worked well with PL1800E.
Previous setup using 2 x AC66U (wireless bridge) is a let down. I will use the new & old powerplugs for my other rooms in future.
If can try out on 1gbps MR or viewquest would generate more interestSineoji 1800 mbps MIMO homeplug speed test comparison with Sineoji 600 mbps on M1 300 mbps fibre broadband.
hmmm interested in getting a pair of homeplugs...
is it advisable to to use a pair of PL600EPG?
The setup would be:
D-Link DVG-N5402SP ---PL600EPG---PL600EGP---My PC
will your powerline work through a extension socket?
how much is the 1800 Mbps homeplugs??Dear kindovic
Yes this configuration works, however, if you are into heavy downloading and HD streaming where speed is a priority, I suggest that you go for the 1800 Mbps instead.
Sineoji
Wat is the price of 1800? Also y 1800 when bcm chip is 1500?
The Sineoji 1800 Mbps Gigabit MIMO HomePlug is powered by Broadcom's 60500 based on 1800 Mbps physical data rate, this is the latest specification.
We have conducted several onsite test for months, as many of whom we wish to thanks for the time taken up especially in the late evenings.
What far most important is the customer experience and satisfaction, that's where we offered our value add service to our audience by having our staff to go onsite to support and check on the customer's powerline condition and how we can improve and educate them. We provide the convenience of exchanging the product at their doorsteps and setting it up to make sure everything works in a good condition.
We need to feel the ground, at the customer's premises. The fact is what you see on the ground may not be seen on the engineering lab when EVT/DVT is conducted.
We initially have a 1200 Mbps homeplug with pass through but we made a decision to proceed with the 1800 Mbps instead.
Sineoji
So frm ur extensive field tests wat is the real world speed we looking at?
Yes it does work on the extension socket but ensure the power extension is not one with surge protection.
MIMO is incorporated in our 1800Mbps Homeplug such that it uses all 3 wires namely, Live, Neutral and Earth for data transmission to optimize the performance and throughput.
Sineoji
