Guys I can't find the link for Microsoft complete extended warranty in sg store. Any body have link thanks.
Need to register your product first, at support page u will see an option to extend warranty. Click it, it will direct u there.
https://www.microsoft.com/surface/en-sg/support/
start from here.
BTW the pen update is under Change PC settings - there is a lot of windows update and firmware to be completed in a step by step manner.
Oh ok Ic thanks. How much isit? Have yet to get my device yet. Waiting for Microsoft student verification side to reply....
does it support 128gb micros?
quite expensive man. but good investment. will check it out tmr coz near my school. if the cuttings are perfect then probably will just get it? since they can apply it also hahaha. any recommendations for a good 64gb micro sd card guys?!
start from here.
Will the screen protectors damage the pen or affect the quality of annotations?
Hey alan, here have your answers already
supports for 128gb microsdxc
There's many range right now...
Samsung is probably the best bet as according to their 32GB, though it is not 64 GB, the review will give you a little light to what you would expect
Reviews
Sandisk extreme plus 64GB
Reviews
Anyone knows which browser is optimised for touch? I am so used to the Safari and Bettertouchtool combo for mac that I find it really difficult to use the normal browsers in SP3 ;(
is your touch gestures smooth? i find zooming in and out in firefox a bit of a lag. finger scrolling also a bit laggy.
Free upgrade? Lol. U dreaming bah.Other thing have to consider when buying Surface:
- RT is dead for sure, no good reason to go for it unless you really need the free office product.
- Win8.1 currently, possible to upgrade to next version of Windows?
when you close your type cover, do you see a gap between the type cover and the tablet ?
ie. is the "top" of the screen , where the camera is located slightly curved compared to where the type cover is connected ?
if not then my screen is warped ??
