Dr_ARCHer
If change the antennae for both AC87U to higher gain ones e.g. +9 dB, would the speed be higher? :D
I only have 3 +9 dB antennae. Need to buy another 5. :eek:
danxiaogui86
Dear SimonLam,
Yes 4T4R PCE coming soon... We are currently trying to design the PCB same length as GTX Titan card.
Trend: longer PCB card >> Winner
Best regard,
JK
Haha! Don't la! My Rig no space for long card liao. currently length okay.
ASUS@SG
Suspended
Should i post my router too?
3 long 1 short :( look weird
Best regard,
JK
SimonLam
Moderator
Moderator
This is from my Room PC via Media Bridge (all equipment back to their normal positions)
Last Result:
Download Speed: 712651 kbps (89081.4 KB/sec transfer rate)
Upload Speed: 474479 kbps (59309.9 KB/sec transfer rate)
Latency: 6 ms
Jitter: 0 ms
‎8‎/‎29‎/‎2014‎ ‎10‎:‎55‎:‎57‎ ‎PM
maylyn
ASUS RT-AC87U Firmware version 3.0.0.4.376.2678
Enhancement and new features.
1. Added the application icons in Bandwidth monitor.
2. Enhanced the Wi-Fi and LED button response time
3. Added reducing USB 3.0 interference switch in network map USB part.
Bug Fixes:
1. Fixed OpenVPN UI issue. OpenVPN client shows disconnect but it still connect to VPN server.
2. Fixed the NTP sync error issue when manually assign the NTP server.
3. Fixed AiCloud compatibility issue when using IE11.
4. Fixed PPTP VPN server connection issue which is caused by special character.
Updated Quantenna driver:
1. Improved long range performance in RT-AC87U connecting to RT-AC87U scenario.
2. Fixed ping test problem in noise environment.
3. Fixed RX buffer overflow in long time stress test.
~> http://dlcdnet.asus.com/pub/ASUS/wireless/RT-AC87U/FW_RT_AC87U_30043762678.zip
maylyn
Hi Dr_Archer,
2678 ~ improved long range performance in RT-AC87U connecting to RT-AC87U.
See whether it's boost more in your case or not :D
Dr_ARCHer
Do you put your antennae as | | | | or \ | | / ?
And I name this the Wolverine router.... the antennae is like Wolverine's claws :D
Dr_ARCHer
New 2678 firmware with no change to settings. Everything else the same
Wow! Just some firmware magic and speeds go up by 20% :D
oric1
5Ghz LED Light
Does anybody have this problem of the 5Ghz LED light constantly going off and back on again (in less than a split second)?
I tried all the factory firmwares and even with Merlin's build but still blinking :(
Is my set faulty or is it a bug? Will it affect my 5Ghz performance? Thanks.
SimonLam
Moderator
Moderator
you mean blinking? yes mine blinks..
SimonLam
Moderator
Moderator
But in the ASUS Quick Start Guide, it says "To ensure the best wireless signal, orient the four detachable antennas as shown in the drawing below:".... which is \ | | / :)
You are correct...hmm...
in AC87U manual, it actually recommends \ | | /, at angle 45, 90, 90, 45.
I going to try out to see if my link speed improve..
Edit: No difference...link speed still 1170
maylyn
Another first ;) :eek:
My 5GHz wireless bridging breaches > 900Mbps mark :eek: :)
1Gbps wired type of speed :D
